D-Link DNS-323 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
Teardown of the D-Link NAS DNS-323.
Fairly easy to open.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — D-Link DNS-323 Teardown  ¶
  • The DNS-323 is a powerful NAS with Gigabit Ethernet, print server and extension via software. It can have a FTP server, DHCP, and even Bittorrent!
    • This is my first disassembling, please be patient, correct my grammar mistakes if you find some.
    • This was pretty easy, nothing compared to iPods or Macs.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • First thing first remove the frontal part by sliding it up and pulling out.
    • You will be able to see the hard disks.
  • By the way, the DNS-323 can support up to 3TB of disk space with the new firmware update. That's 1.5TB per disk! Could you imagine such capacity twenty years ago?
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Now it's time to remove the Hard Disks.
  • BE CAREFUL, when handling these parts do not touch the circuits, do not shock, and to not make your dog play with them. I'm serious, this could lead into data loss.
    • At the back of the DNS pull out the two little levers to make the hard drives come out.
    • Gently take them and keep in a safe place until the whole unit is reassembled.
  • The drives are order-sensitive! Remember if they were right or left, otherwise you will be prompted a message when accessing the NAS.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Remove the frontal part.
    • There are two screws, remove them with a cross screwdriver.
    • After that pull off the little sheet of metal that's covering the front.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • Now it's time to open the rear.
    • You have to remove four rubber lids which cover the screws, so remove them with a flat screwdriver and then so on with the screws.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Take off the rear and unscrew the next four screw showed in the picture.
  • These screws are hard! Pay attention not to strip them!
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • Pull the board to make it slide off the case.
  • The board is quite simple, a little ARM-based computer mounting Linux. (is it?), all condensers are most for power supply, doubled because of the two HDDs.
    • Remove two more screws under the circuit.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8  ¶
  • Time to remove the iron part.
    • Pull out the fan wire. If you need you can use a flat screwdriver, paying attention not to break it.
    • It's time to detach the SATA adapters with the fan, so you can contemplate the main circuit.
  • Don't remove the battery, this could lead to time loss, some basic settings (not all because most of them are stored inside the HDs) and unwanted resets.
Next » « Previous
Required Tools
Flathead 3/32" or 2.5 mm Screwdriver
$4.95 · 50+ in stock
Phillips #1 Screwdriver
$8.95 · 15 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 38 in stock
Anti-Static Wrist Strap
$7.95 · 17 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
Metal Spudger
$2.95 · 50+ in stock
Small Suction Cup
Notes Add Note Notes are offturn on
