This teardown is not a repair guide. To repair your Cyclops Helios, use our service manual.
  1. Cyclops Helios Teardown, Cyclops Helios Teardown: step 1, image 1 of 1
    • Power off Cyclops Helios before tearing down by pushing the black button until the LEDs no longer emit visible light.
    • Black button - circled in red
  2. Cyclops Helios Teardown: step 2, image 1 of 3 Cyclops Helios Teardown: step 2, image 2 of 3 Cyclops Helios Teardown: step 2, image 3 of 3
    • Using two hands, carefully separate the front panel and back panel of the Cyclops Helios.
    • Front panel - boxed in red
    • Back panel - boxed in blue
  3. Cyclops Helios Teardown: step 3, image 1 of 2 Cyclops Helios Teardown: step 3, image 2 of 2
    • Use a Phillips head screwdriver to remove two screws from the front panel.
    • The two screws fasten the outer enclosure with the inner electronics of the front panel.
  4. Cyclops Helios Teardown: step 4, image 1 of 3 Cyclops Helios Teardown: step 4, image 2 of 3 Cyclops Helios Teardown: step 4, image 3 of 3
    • Within the enclosure of the front panel there is a clear plastic lens, and plastic button insert. Both are removable.
    • Clear plastic lens - boxed in red
    • Plastic button insert - circled in blue
  5. Cyclops Helios Teardown: step 5, image 1 of 3 Cyclops Helios Teardown: step 5, image 2 of 3 Cyclops Helios Teardown: step 5, image 3 of 3
    • The inner electronics of module of the front panel includes a parabolic mirror, circuit board, and battery holder.
    • Circuit board - boxed in blue
    • Parabolic mirror - boxed in red
    • Battery holder - boxed in green
  6. Cyclops Helios Teardown: step 6, image 1 of 2 Cyclops Helios Teardown: step 6, image 2 of 2
    • Separate the circuit board from the battery holder by desoldering the black and red wires from the battery holder.
Shaun Koide
161 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 22
All Time: 913
