Commodore 1341 Joystick Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
Let's have a look inside a retro Commodore 64 joystick.
first image
Add Note Edit Step 1 — Commodore 1341 Joystick Teardown  ¶
  • Introduced in 1984, the Commodore 1341 joystick was designed for use with the Commodore range of computers including the Commodore 64, 128, VIC20 and Commodore Plus4.
  • This joystick connects to the retro computers using a 9 pin connection.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • The joystick is held together by five phillips head screws. One screw is located on the handle and the remaining four are under the base.
  • Once the screws have been removed you can pry the case apart using a flat head screw driver. Just be careful with the base as it is spring loaded and it can fly apart quite easily.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • You will need to desolder the fire button cables from the board.
  • Pry the case open but watch for the spring. There is also a rubber bung that sits beneath the black rocker shaft.
  • Desolder the cables from the main joystick board and remove all of the components.
  • Now you are ready to clean all of the joystick components and reassemble.
