This teardown is not a repair guide. To repair your Car Charger, use our service manual.
  1. Car Charger Teardown, Car Charger Teardown: step 1, image 1 of 3 Car Charger Teardown, Car Charger Teardown: step 1, image 2 of 3 Car Charger Teardown, Car Charger Teardown: step 1, image 3 of 3
    • PureGear's Extreme USB Car Charger is an elegant cigarette lighter car charger with a smooth, matte outer casing.
    • This charger is able to charge devices with Qualcomm Quick Charge 2.0 compatible processors up to 4 times faster.
    • The adapter is rated at 12W with 5V/2.4A for Quick Charge compatible devices and 5V/1A for all others.
    • The charger includes:
    • USB adapter
    • LED to indicated status of charge
  2. Car Charger Teardown: step 2, image 1 of 2 Car Charger Teardown: step 2, image 2 of 2
    • Just like most car chargers, the case does not have an obvious entry point.
    • In order to get into the inner working, we will need to use our trusty plastic opening tool to pry off the lid to the charger.
    • The lid is easy enough to remove and the green rim slides right out as well.
  3. Car Charger Teardown: step 3, image 1 of 1
    • Now we get out first glimpse at the circuitry that allows our Quick Charge 2.0 compatible devices to charge...well quick.
    • From here we can see:
    • USB adapter
    • LED that shows charge status
    • A big capacitor
    • Some USB chip (assuming its proximity to the USB adapter)
  4. Car Charger Teardown: step 4, image 1 of 3 Car Charger Teardown: step 4, image 2 of 3 Car Charger Teardown: step 4, image 3 of 3
    • To separate the last part of the outer shell, we need to apply some pressure from with the vice grip pliers.
    • Squeezing the shell across the seem causes the connecting tabs to separate enough for us to pry them apart.
    • Inside the shell are three metal leads that fell out when the shell pieces separated.
  5. Car Charger Teardown: step 5, image 1 of 3 Car Charger Teardown: step 5, image 2 of 3 Car Charger Teardown: step 5, image 3 of 3
    • Finally we can see what makes this charger tick and It seems that there are two important chips at work here:
    • Active-Semi ACT4533C DC/DC Converter
    • Power Integrations CHY100D-TL Battery Management Charger Interface
    • These two chips in tandem make this CLA possible with so few parts, including:
    • a couple resistors and capacitors
    • an inductor
    • a fuse
    • and two diodes
  6. Car Charger Teardown: step 6, image 1 of 1
    • PureGear Extreme USB Car Charger Repairability Score: 7 out of 10 (10 is easiest to repair)
    • It was very easy to remove the lid of the casing
    • There are few parts to disassemble
    • There was not an obvious way to separate the two halves of the outer casing
    • The charger reassembled very easily without any need for repair
    • It's amazing how PureGear was able to make a Quick Charge 2.0 compatible charger with so few parts.
Oliver
251 Reputation
2 Guides authored
3 Comments
Any info on the USB chip?
Paul Hendrix - Reply
I need help fixing a car charger. I think the fuse is blown. It's an Ainope AV804. I don't see how to take the face off. I'd rather send it to you for repair.
Please email me at: WFBanach@aol.com
Wallace Banach - Reply
Great insight on how to open one of these. I had a different vendor adapter and it opened almost exactly like the one you showed.
Thanks!
Marc - Reply
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 84
All Time: 16,430
