This teardown is not a repair guide. To repair your Cabstone Wired Optical Mouse, use our service manual.
  1. Cabstone Wired Optical Mouse Teardown, Cabstone Wired Optical Mouse Teardown: step 1, image 1 of 2 Cabstone Wired Optical Mouse Teardown, Cabstone Wired Optical Mouse Teardown: step 1, image 2 of 2
    • Unplug the USB cord of the mouse from your PC first!
    • Remove the lower glide pads at the bottom of the mouse.
    • Use a screw driver to remove the screws highlighted here.
  2. Cabstone Wired Optical Mouse Teardown: step 2, image 1 of 2 Cabstone Wired Optical Mouse Teardown: step 2, image 2 of 2
    • Lift the cover where the screws sat and shift it backwards slightly (away from the cable). Everything else inside the mouse comes loose with this step.
  3. Cabstone Wired Optical Mouse Teardown: step 3, image 1 of 3 Cabstone Wired Optical Mouse Teardown: step 3, image 2 of 3 Cabstone Wired Optical Mouse Teardown: step 3, image 3 of 3
    • The electronics board contains:
    • 5 small buttons
    • one mechanical rotary encoder (of the mouse wheel)
    • one LED
    • the sensor IC Pixart PAN3101DB
raumschaum
371 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 78
All Time: 4,978
