BlackBerry Presenter Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
This thing landed in our laps. We tried it, tested it, and then ripped it apart! All information can be found at www.phonewreck.com.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — BlackBerry Presenter Teardown  ¶
  • The BlackBerry Presenter
    • ~$200
    • Solid Design
    • A clever design trick,the Power Button is the Blackberry Logo
first image
Add Note Edit Step 2  ¶
  • Moving around the back, we see all of the ports
  • VGA Port
  • S Video Port
  • Micro Usb
  • NTSC/PAl Switch
first image
Add Note Edit Step 3  ¶
  • Peel back the Rubber pad on the bottom of the device.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Grab your T7 and poke it through the adhesive pad.
    • Remove the four screws. The top portion of the device should lift free, pretty easily.
first image
Add Note Edit Step 5  ¶
  • There's the PCB! Now to get under it..
first image
Add Note Edit Step 6  ¶
  • Grab a small wrench or a pair of pliers and remove the screws holding in the VGA port.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Focus Enchancments : FS455LF 0731 kox4h00 is a TV encoder designed for applications which require Component Video, VGA, or RGB output capabilities.It can accept digital video or computer graphics in many different resolutions and rates, and convert them to high quality analog video.
  • TI TMS320 DM350ZWX
  • ST microelectronics
