BlackBerry PlayBook Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
The BlackBerry PlayBook came out on the morning of April 19. We had our tools ready to take it apart and investigate its innards.
Like knowing about the inner workings of the latest gadgets? Follow us on Twitter to get the latest scoop.
Check out MJ's video analysis of all the cool stuff we found in the PlayBook!
Image #1 Image #2
Add Note Edit Step 1 — BlackBerry PlayBook Teardown  ¶
  • BlackBerry's new PlayBook has hit the market with a name containing both entertainment and literary promise.
    • Such a bold name instills in us feelings similar to those felt by preteen girls minutes before a Justin Bieber concert.
  • Tech Specs:
    • 7" Capacitive Touchscreen with Multitouch Support
    • 1 GHz TI OMAP 4430 Dual Core Processor
    • 1 GB RAM
    • Dual HD Cameras (3MP and 5MP in the front and back, respectively)
  • Surprisingly, the PlayBook lacks support for mobile broadband.
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • As we examine the device, the camera atop its sleek front stares back at us. The white dot to the left of the front camera is a notification LED.
  • The PlayBook feels impressive in the hands. The metal frame around its front glass panel, rubberized rear panel, and its overall heft makes us almost forget about its questionable software.
  • A small magnetic dock connector for charging on the bottom edge of the PlayBook is reminiscent of one of our favorite features of Apple's laptops.
Image #1
Add Note Edit Step 3  ¶
  • We insert a plastic opening tool into the PlayBook's rim, and pray to the gods of electronics that the front panel doesn't shatter.
    • Just to be clear, it didn't shatter.
  • Thankfully, strategically placed clips around the back of the plastic rear panel secure it to the front panel assembly without the use of screws or adhesive.
Image #1
Add Note Edit Step 4  ¶
  • Upon releasing the clips surrounding the perimeter, the rear case can be removed.
  • Unlike other popular tablets, the PlayBook's guts are not housed within the back cover but are instead attached to the display assembly.
  • The PlayBook has a 20 watt-hour battery, which is a bit smaller than the iPad 2's 25 watt-hour and the Xoom's 24 watt-hour battery.
    • Even though the battery in the PlayBook has a smaller capacity, the battery life is rumored to be comparable to the iPad 2 and Xoom, although official numbers have not yet been released.
Add Note Edit Step 5  ¶
  • Now we can remove a pair of screws from the battery connector with a Phillips #00 screwdriver.
  • Next we pry off the battery connector to bring us one step closer to the goods.
  • We continue by prying off all the other connectors from the motherboard.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Next we remove a couple Phillips screws from the motherboard.
  • In an array of light showering us from the BlackBerry heavens (not pictured), we remove the motherboard from the PlayBook.
Image #1
Add Note Edit Step 7  ¶
  • Front view of the motherboard. If you want the super-huge version of the motherboard, click here.
    • Elpida B8064B2PB-8D-F 1GB DRAM & the TI OMAP4430 1GHz dual-core processor
    • SanDisk SDIN5C2-16G 16 GB NAND Flash
    • Texas Instruments TWL6030 Power Management
    • STMicroelectronics XTV0987 5 MP mobile imaging processor
    • Wolfson WM8994E audio codec
    • Texas Instruments WL1283 GPS/WLAN/Bluetooth/FM
    • TriQuint Semiconductor TQP6M9002 802.11a/b/g/n + BT front-end module
Image #1
Add Note Edit Step 8  ¶
  • And the rear view of the motherboard. (Here's the super-huge version):
  • Texas Instruments LMV339 Quad General Purpose Low-Voltage Comparators
  • Texas Instruments SN74AVCH4T245 4-Bit Dual-Supply Bus Transceiver with Configurable Voltage Translation and 3-State Outputs
  • Bosch Sensortec BMA150 Digital 3-axis accelerometer
  • Invensense MPU-3050 3 axis gyroscope
  • Texas Instruments PS63020 High Efficiency Single Inductor Buck-Boost Converter with 4A Switch
  • A big thanks to Chipworks for helping us identify the components inside the PlayBook!
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 15 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
iPhone 4S Display Assembly
$94.95 · 21 In stock
iPhone 3GS Replacement Battery
$19.95 · 50+ In stock
Anti-Static Mat
$24.95 · 50+ In stock
Probe and Pick Set
$6.95 · 50+ In stock
