This teardown is not a repair guide. To repair your Black Diamond Moxie, use our service manual.
  1. Black Diamond Moxie Teardown, From the Outside: step 1, image 1 of 3 Black Diamond Moxie Teardown, From the Outside: step 1, image 2 of 3 Black Diamond Moxie Teardown, From the Outside: step 1, image 3 of 3
    • Pull here to open the battery case
  2. Black Diamond Moxie Teardown, The Battery Case: step 2, image 1 of 2 Black Diamond Moxie Teardown, The Battery Case: step 2, image 2 of 2
    • Space for three AAA batteries here
    • Unscrew these
    • and these phillips screws here.
    • Keep in mind, that this are different screws, so don't mix them
    • This part will be a bit complicated to get it back together
  3. Black Diamond Moxie Teardown, The Front: step 3, image 1 of 3 Black Diamond Moxie Teardown, The Front: step 3, image 2 of 3 Black Diamond Moxie Teardown, The Front: step 3, image 3 of 3
    • The front has three parts
    • The case,
    • the reflector
    • and the lens.
  4. Black Diamond Moxie Teardown, The PCB: step 4, image 1 of 2 Black Diamond Moxie Teardown, The PCB: step 4, image 2 of 2
    • The "high power" LED with 55 lumens
    • This seems to be a cooling plate for the high power led
    • The other two LEDs with 16 lumes
    • The button
  5. Black Diamond Moxie Teardown, The Light Spot without the Lens: step 5, image 1 of 2 Black Diamond Moxie Teardown, The Light Spot without the Lens: step 5, image 2 of 2
    • The high power LED would make a way better near field wide angle lamp without the lens.
    • In reality the light is even broader distributed than visible on the image.
    • This is the light spot of the two low power LEDs.
  6. Black Diamond Moxie Teardown, The Manual: step 6, image 1 of 2 Black Diamond Moxie Teardown, The Manual: step 6, image 2 of 2
    • The english part of the manual
Quanten
1,013 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 1,417
