Banana Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
In this teardown, we open a banana to see what's inside. Yellow and delicious, but most importantly, yellow.
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Banana Teardown  ¶
  • Take one banana from the bunch.
  • Don't squeeze too hard!
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Hold the banana in your left hand and grip the stem between your right thumb and forefinger.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Pull the stem downward until the peel splits.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Insert your thumbs into the split of the peel and pull the two sides apart.
  • Expose the top of the banana. It may be slightly squished from pulling on the stem, but this will not affect the flavor.
first image
Add Note Edit Step 5  ¶
  • Pull open the peel, starting from your original split, and opening it along the length of the banana.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Remove fruit from peel.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Eat and enjoy!
  • This is where you'll need your teeth.
  • Do not choke on banana!
Popular Products
iPhone 3GS Display Assembly
$99.95 · 13 in stock
Magnetizer/Demagnetizer
$4.95 · 50+ in stock
Jeweler's Loupe LED Magnifier
$9.95 · 50+ in stock
Pro Tech Toolkit Expansion 1
$79.95 · 48 in stock
Notes Add Note Notes are offturn on
