Baby Monitor Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
This hand-me-down baby monitor has a busted volume/on-off switch. Monitor only operates while pressing down on the volume dial. If you think I have the energy to hold down that dial while trying to sleep, you got another thing coming. Baby crying... gotta go.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Baby Monitor Teardown  ¶
  • Here is the baby monitor in all its glory.
  • Start by turning the device speaker-side down.
  • Remove the flathead screw securing the battery cover using a flathead screwdriver.
  • Remove the battery cover after fully disengaging the screw.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Remove the batteries from the compartment.
  • Remove the five phillips screw holding the casing together using a phillips #1 screwdriver.
    • The fifth screw is hidden beneath the battery cover, toward the center of the monitor and is recessed deep into the casing.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • CAUTION: Do not yank the casing apart!!!
  • Gently pry from the bottom and work a finger along the side and until monitor pops in half.
  • The speaker cabling is soldered to the main board and the speaker is stuck in the front casing with adhesive.
  • Lay the two halves as shown.
first image
Add Note Edit Step 4  ¶
  • Remove the two screws securing the main board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • Pry lightly around the edge of the main board between the board and the casing to help free the board. Fingernails, a spudger, or plastic opening tools can be used for this task.
  • DO NOT TRY TO REMOVE THE MAIN BOARD COMPLETELY!!! There are soldered items that need to be dealt with. Follow along closely.
  • Gently, and I mean gently, pull up on the LED assembly to loosen the main board from the rear casing.
  • Any resistance should indicate that the board needs to be loosened from the casing, around the edges, more before proceeding.
first image
Add Note Edit Step 6  ¶
  • PROCEED WITH CAUTION!!! The antenna cable and the battery contacts are soldered onto the board.
  • Your monitor should look like this, with a small gap between the main board and the rear casing.
  • The next step will merely free the volume control dial from the casing and NOT free the main board from the casing.
  • To remove the main board from the casing, you MUST desolder the antenna cable and two battery contacts from the board.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • Create about a 30 degree angle between the rear casing and your workspace, lifting the casing by the top end. I used 3 decks of playing cards to prop up the casing from my workspace.
  • Lift the main board from the rear casing at the bottom, making sure the volume dial clears the screw retainer post. DO NOT COMPLETELY REMOVE MAIN BOARD!
  • Once free, set the main board back down on the casing.
  • You are now free to desolder any of the contacts that need repair. In my situation, I will be examining the volume dial and will not need to desolder.
  • Good luck!
Required Tools
Phillips #1 Screwdriver
$8.95 · 39 in stock
6-in-1 Screwdriver
$4.95 · 14 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 21 in stock
Sorting Tray
$7.95 · 15 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
Popular Products
iPhone 4S Display Assembly
$129.95 · 49 in stock
Flathead 3/32" or 2.5 mm Screwdriver
$4.95 · 50+ in stock
Small Suction Cup
$2.95 · 50+ in stock
Heat Gun
$24.95 · 8 in stock
Sorting Tray
$7.95 · 15 in stock
