This teardown is not a repair guide. To repair your Arlo Ultra 2, use our service manual.
  1. Arlo Ultra 2 Teardown, Arlo Ultra 2 Teardown: step 1, image 1 of 3 Arlo Ultra 2 Teardown, Arlo Ultra 2 Teardown: step 1, image 2 of 3 Arlo Ultra 2 Teardown, Arlo Ultra 2 Teardown: step 1, image 3 of 3
    • Features:
    • 4K Video with HDR
    • Color Night Vision
    • Integrated Spotlight
    • 180° Viewing Angle
    • Crystal Clear 2-Way Audio
    • Weather Resistant
    • Advanced SmartHub
  2. Arlo Ultra 2 Teardown: step 2, image 1 of 2 Arlo Ultra 2 Teardown: step 2, image 2 of 2
    • To open the Arlo Ultra Camera, press the Button on the bottom, and pull Camera Face (Camera Body) away from the Camera Enclosure
    • Set the Camera Enclosure to the side. It will not be needed for the rest of the Teardown
  3. Arlo Ultra 2 Teardown: step 3, image 1 of 2 Arlo Ultra 2 Teardown: step 3, image 2 of 2
    • Remove the Battery from the Camera Body by gently pulling the Battery away from the Camera Body
    • The Battery Capacity is 4800mAh
  4. Arlo Ultra 2 Teardown: step 4, image 1 of 2 Arlo Ultra 2 Teardown: step 4, image 2 of 2
    • To remove the Camera Face Plate from the Camera Body, remove the four PH00 screws in the Battery Compartment Area that secure the Camera Face Plate to the Camera Body
    • Use the Spudger Tool to pop off the Camera Faceplate
  5. Arlo Ultra 2 Teardown: step 5, image 1 of 2 Arlo Ultra 2 Teardown: step 5, image 2 of 2
  6. Arlo Ultra 2 Teardown: step 6, image 1 of 3 Arlo Ultra 2 Teardown: step 6, image 2 of 3 Arlo Ultra 2 Teardown: step 6, image 3 of 3
    • With the Camera Face Plate removed, use the Spudger Tool to pry the Camera Assembly away from the Camera Body
    • Once the Camera Assembly comes loose from the Camera Body, use the Spudger Tool to pry against the two plastic tabs on the bottom of the Camera Assembly that hold the Camera Assembly to the Camera Body PCB (Main PCB)
    • Pull the Camera Assembly away from the Assembly Body
    • The Camera Assembly is held in place by Zero Insertion Force Connectors to the Main PCB in the Camera Body
  7. Arlo Ultra 2 Teardown: step 7, image 1 of 3 Arlo Ultra 2 Teardown: step 7, image 2 of 3 Arlo Ultra 2 Teardown: step 7, image 3 of 3
    • With the Spudger Tool, pry off the cable to the Speaker / Siren from the Speaker Connector
    • With the Spudger Tool, release the Flex Cables attached to the Small PCB on the back of the Camera Assembly
  8. Arlo Ultra 2 Teardown: step 8, image 1 of 3 Arlo Ultra 2 Teardown: step 8, image 2 of 3 Arlo Ultra 2 Teardown: step 8, image 3 of 3
    • With the Flex Cables released from the Small PCB on the back of the Camera Assembly, remove the two PH00 screws that hold the Metal Bracket in place
    • Use the Spudger Tool to pop off the Metal Bracket
  9. Arlo Ultra 2 Teardown: step 9, image 1 of 2 Arlo Ultra 2 Teardown: step 9, image 2 of 2
    • With the Spudger Tool, pry out the Small PCB on the back of the Camera Assembly
  10. Arlo Ultra 2 Teardown: step 10, image 1 of 2 Arlo Ultra 2 Teardown: step 10, image 2 of 2
    • Now that the Small PCB has been removed, we can review the components on the PCB. Some parts could not be crossed referenced. Please leave a comment if you happen to know a part or parts.
    • Small PCB Topside
    • U1 Part Markings: 3070, TI 861, AXLY
    • Small PCB Backside
    • U24 Part Markings: PA81, TI 686, A6KS
    • U41 DSP Group D2A3X - Audio DSP
    • U5 Part Markings: 18M
    • U43 TI TAS2560 - 5.6W Class D Mono Audio Amp
  11. Arlo Ultra 2 Teardown: step 11, image 1 of 3 Arlo Ultra 2 Teardown: step 11, image 2 of 3 Arlo Ultra 2 Teardown: step 11, image 3 of 3
    • Remove the Large EMI / Heatsink Shield from the back of the Camera Assembly by removing the two PH00 Screws
    • Pry off the Large EMI / Heatsink Shield from the Camera Assemble using the Spudger Tool
  12. Arlo Ultra 2 Teardown: step 12, image 1 of 3 Arlo Ultra 2 Teardown: step 12, image 2 of 3 Arlo Ultra 2 Teardown: step 12, image 3 of 3
    • With the Large EMI / Heatsink Shield removed, we can now remove the Flex PCB that contains the Microphones, Light Detector, Multi-Color LED and PIR Sensor
    • Use a pair of Long Needle Nose Pliers to pull the Metal Shield Tape from the backside of the Camera Assemble Body.
    • From the frontside of the Camera Assembly Body, pull the Metal Shielding Tape through the hole to the backside of the Camera Assembly Body
    • Use the Spudger Tool to gently pry out the Flex PCB. The Flex PCB is held in place by double stick foam tape
    • The Speaker / Siren can also be removed after the Metal Shield Tape has been removed by pulling the speaker cable through the hole between the backside and frontside of the Camera Assembly Body that was occupied by the Metal Shield Tape
  13. Arlo Ultra 2 Teardown: step 13, image 1 of 2 Arlo Ultra 2 Teardown: step 13, image 2 of 2
    • After removing the the Flex PCB, remove the Metal Shield Tape from the Flex PCB
  14. Arlo Ultra 2 Teardown: step 14, image 1 of 3 Arlo Ultra 2 Teardown: step 14, image 2 of 3 Arlo Ultra 2 Teardown: step 14, image 3 of 3
  15. Arlo Ultra 2 Teardown: step 15, image 1 of 2 Arlo Ultra 2 Teardown: step 15, image 2 of 2
  16. Arlo Ultra 2 Teardown: step 16, image 1 of 2 Arlo Ultra 2 Teardown: step 16, image 2 of 2
    • Frontside and Backside Close up Views of the Left Side Microphone on the Flex PCB
    • TDK ICS-41350 Microphone
  17. Arlo Ultra 2 Teardown: step 17, image 1 of 1
    • PIR Sensors, Light Detector, and Mutli-Color LED Close up View
  18. Arlo Ultra 2 Teardown: step 18, image 1 of 1
    • Close Up View of the Speaker / Siren
    • NG521-0015-01B18100010711
  19. Arlo Ultra 2 Teardown: step 19, image 1 of 1
    • After the Flex PCB has been removed, the Camera Lens plus Image Sensor PCB can be gently pulled out from the Camera Assembly Body
  20. Arlo Ultra 2 Teardown: step 20, image 1 of 3 Arlo Ultra 2 Teardown: step 20, image 2 of 3 Arlo Ultra 2 Teardown: step 20, image 3 of 3
    • Use the PH00 Tool, to remove the the two screws holding the the Spot Light LEDs and Infrared Light LEDs PCB to the Camera Assembly Body
    • Close up view of the Spot Light LEDs, and Infrared Light LEDs
    • Spot Light (400 Lumens)
    • Infrared Light LEDs
  21. Arlo Ultra 2 Teardown: step 21, image 1 of 3 Arlo Ultra 2 Teardown: step 21, image 2 of 3 Arlo Ultra 2 Teardown: step 21, image 3 of 3
    • Use the Spudger Tool to release the Camera's Mechanical Focus Motor Control Cable
    • Use the PH00 Tool to remove the three screws holding the Camera Lens to the Image Sensor PCB
  22. Arlo Ultra 2 Teardown: step 22, image 1 of 3 Arlo Ultra 2 Teardown: step 22, image 2 of 3 Arlo Ultra 2 Teardown: step 22, image 3 of 3
    • Close Up View of the 4K Image Sensor PCB. The Image Sensor has no part number that could be cross referenced. Leave a comment, if you know the part number of the Image Sensor.
    • Close Up View of the backside of the Image Sensor PCB
    • U4 Part Markings: PA81, TI 878, A5X3
    • Please leave a comment if you know the part number for U4
    • Close Up View of the Camera Lens
  23. Arlo Ultra 2 Teardown: step 23, image 1 of 2 Arlo Ultra 2 Teardown: step 23, image 2 of 2
    • Remove the Main PCB from the Camera Body by gently prying it out using the Spudger Tool
  24. Arlo Ultra 2 Teardown: step 24, image 1 of 2 Arlo Ultra 2 Teardown: step 24, image 2 of 2
    • The Main PCB has EMI / Heatsink Shielding on the frontside and backside
  25. Arlo Ultra 2 Teardown: step 25, image 1 of 3 Arlo Ultra 2 Teardown: step 25, image 2 of 3 Arlo Ultra 2 Teardown: step 25, image 3 of 3
    • The Small EMI/Heatsink Shield is not soldered on and can be easily removed with a Dental Pick Tool
    • Use the Dental Pick Tool to pry up the sides of the EMI/Heatsink Shield
    • Once the EMI/Heatsink Shield has been loosen, it can easily be pulled off the rest of the way
  26. Arlo Ultra 2 Teardown: step 26, image 1 of 3 Arlo Ultra 2 Teardown: step 26, image 2 of 3 Arlo Ultra 2 Teardown: step 26, image 3 of 3
    • The Large EMI/Heatsink Shield is not soldered on and can be easily removed with a Dental Pick Tool
  27. Arlo Ultra 2 Teardown: step 27, image 1 of 2 Arlo Ultra 2 Teardown: step 27, image 2 of 2
    • Main PCB Front Side Close Up View. Please leave a comment if you know information about U5, U41,U37,U24, U32
    • U2 - Winbond 128m-bit SPI Flash, W25Q128FWP6
    • U5 Part Marking: 1200, P68, AC5F
    • U41, U37, U24 Part Markings: PA81, TI 878, A5X2
    • U32 Part Marking: GT, 43, 828
  28. Arlo Ultra 2 Teardown: step 28, image 1 of 2 Arlo Ultra 2 Teardown: step 28, image 2 of 2
  29. Arlo Ultra 2 Teardown: step 29, image 1 of 2 Arlo Ultra 2 Teardown: step 29, image 2 of 2
    • Close Up View of the WiFi / Bluetooth Antennas
  30. Arlo Ultra 2 Teardown: step 30, image 1 of 1
    • Teardown Exploded View of the Arlo Ultra 4K Wire-Free HDR Security Camera
Robert Shuler
3,549 Reputation
11 Guides authored
7 Comments
I would like to know if its possible to buy the camera lens, anyone know?
simon simonsson - Reply
I also need a lens. I have one camera that broke a lens when it fell.
Stephen -
Even I also have the same question regarding the camera lens.I have another query to add on that I have two Arlo Ultra home security cameras.
I have purchased them for a couple years ago.I am facing an issue concurrently about the “Arlo Camera Offline Error”.I have tried out all the manuals as directed arlo security camera review .Guide us what we have missed out?
Claudia Smith - Reply
I also have a camera that shows offline after the battery died. I can’t get it to reconnect even with other batteries. It won’t charge a battery and there is no LED activity either.
Stephen -
See last two comments. I had two cameras with different issues so I thought I would swap the lens across. The one with the broken lens is also offline now. So still no solution.
Also the Arlo online support has not been responding even when I’m logged in. So not sure what the warranty is worth.
Stephen - Reply
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 94
All Time: 9,599
