Apple Studio Display M2454 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
Here you will see a breakdown of the Apple Studio Display M2454. This will be useful in repairing broken or malfunctioning parts in the future.
first image
Add Note Edit Step 1 — Apple Studio Display M2454 Teardown  ¶
  • Notice that the main components of the monitor are only accessible from the back of the device.
first image
Add Note Edit Step 2  ¶
  • Locate the four hex head screws located on the corners of the back panel.
    • Remove the screws with a 2mm hex screwdriver.
first image
Add Note Edit Step 3  ¶
  • Remove the clear and gray back panels.
first image
Add Note Edit Step 4  ¶
  • Remove the three screws with #2 phillips head screwdriver.
first image
Add Note Edit Step 5  ¶
  • To remove the metal panel, push towards the bottom of the monitor to release its clips and pull the panel away.
first image
Add Note Edit Step 6  ¶
  • Remove screw holding the plastic bracket with #2 Phillips head screwdriver.
first image
Add Note Edit Step 7  ¶
  • Remove the four screws on the metal bracket.
first image
Add Note Edit Step 8  ¶
  • Remove the two philips head hold-down screws with the #2 Phillips head screwdriver.
first image
Add Note Edit Step 9  ¶
  • Remove black connector by pushing the end of the tab closest to the wiring and pulling away from board.
first image
Add Note Edit Step 10  ¶
  • Remove white connector by lifting tab and pulling away from board.
    • Be careful when lifting tabs, they break easily.
first image
Add Note Edit Step 11  ¶
  • Remove connector connected to the hold down previously removed simply by pulling with hand.
first image
Add Note Edit Step 12  ¶
  • Now that the main computer cable is detached, remove it away from monitor.
first image
Add Note Edit Step 13  ¶
  • Remove the two screws holding the USB port in place with #2 Phillip's head screwdriver.
first image
Add Note Edit Step 14  ¶
  • Remove the screw on the wire hold down with #2 Phillips head screwdriver.
first image
Add Note Edit Step 15  ¶
  • Remove white connector connected to LCD main board by lifting tab with tool and pulling away from board.
first image
Add Note Edit Step 16  ¶
  • The USB port is now detached, remove it from monitor.
first image
Add Note Edit Step 17  ¶
  • Remove connector on the left bottom corner of the LCD main board by simply pulling with hand.
first image
Add Note Edit Step 18  ¶
  • Remove the connector on the bottom right corner by 1st removing tape first and pulling with hand.
first image
Add Note Edit Step 19  ¶
  • Remove top right connector of the LCD main board by pulling with hand.
first image
Add Note Edit Step 20  ¶
  • Remove the final connector of the LCD main board by pulling with hand.
first image
Add Note Edit Step 21  ¶
  • Remove the four screws on each corner of the main board with #2 Phillips head screwdriver.
first image
Add Note Edit Step 22  ¶
  • The board is now detached, remove it from monitor.
first image
Add Note Edit Step 23  ¶
  • Locate the top and bottom connector on the CCFL inverter and remove it by inserting pin into the small holes and pulling away.
    • This step may be easier with two people.
first image
Add Note Edit Step 24  ¶
  • Remove the two screws on the top and bottom of the CCFL inverter with #2 Phillips head screwdriver.
first image
Add Note Edit Step 25  ¶
  • The CCFL inverter is now detached, remove it from monitor.
first image
Add Note Edit Step 26  ¶
  • You have no successfully taken apart a Apple Studio Display M2454.
