Kindle 2 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Our Kindle 2 shipped on Monday, February 23rd, a day early. Thanks to UPS Next Day Air, we have the reader in our hands Tuesday morning.
Image #1
Add Note Edit Step 1 — Kindle 2 Teardown  ¶
  • It's here!
  • Thanks to the magic of E-Ink, the Kindle comes with setup instructions displayed on the screen itself. No plugging in is required.
  • We'll post updates on twitter about interesting things that we discover as we go.
Image #1
Add Note Edit Step 2  ¶
  • What comes in the box:
    • A quick start guide, complete with embossed letters
    • An AC adapter
    • The Kindle 2
  • Conveniently, the AC adapter can be used with either a wall outlet or a USB port.
Image #1
Add Note Edit Step 3  ¶
  • Size comparison: Definitely not as big as a 17" MacBook Pro Unibody.
  • The Kindle 2 weighs only 10.2 ounces. Per pound, that makes the Kindle 2 even more expensive than the $2,799 MacBook Pro 17" Unibody we took apart last week.
Image #1
Add Note Edit Step 4  ¶
  • The back. Nothing special about it.
  • Note the speaker holes on the bottom. We briefly tried the Text-to-Speech feature and were very impressed by the Kindle 2's ability to read the text displayed on-screen. But the honeymoon was quickly over and we started tearing into it.
  • Hopefully the insides will be more exciting... We'll let you know as soon as we can!
Image #1 Image #2
Add Note Edit Step 5  ¶
  • Prying the back off...
  • Getting inside is easy once you know how. We used some plastic opening tools and a metal spudger, and finally managed to get in.
  • The matte-gray top cover comes off first.
  • There are two Phillips screws to remove before the Aluminum back can be removed entirely.
Image #1
Add Note Edit Step 6  ¶
  • We're in!
  • It's still not very pretty; just more white plastic.
  • Twenty Phillips screws hold the white plastic paneling in place.
  • Interestingly, nothing was attached to the large white and brown connector near the top of the board.
Image #1 Image #2 Image #3
Add Note Edit Step 7  ¶
  • Remove two Phillips screws and the battery lifts out easily.
  • The battery is Model No. S11S01A. It's a 3.7 V, 1530 mAh lithium polymer battery. The battery weighs in at 31 grams, just over 10% of the Kindle's total weight.
  • The wireless card is also easily removable by removing two Phillips screws.
  • There are two antenna ports on the wireless card, but there was nothing connected to the AUX port in our Kindle.
Image #1
Add Note Edit Step 8  ¶
  • After removing sixteen more screws, we've made it to the main PCB.
  • Everything exciting is still beneath silver EMI shields.
  • The Kindle was designed by Lab126, a secretive Amazon subsidiary based in Cupertino that designs consumer devices. Thus far, they have only released the Kindle 1 and 2.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 30 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 19 In stock
Popular Products
iPhone 4S Display Assembly
$94.95 · 50+ In stock
iPad Retina Front Panel
T6 Torx Screwdriver
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
26 Bit Driver Kit
$19.95 · 43 In stock
