Page 1 of 1
4.8V Vacuum Cleaner Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
Incorrect Bullets
This guide contains bullet colors that do not match markup, or improperly-used bullet types.
Incorrect Tools
This guide contains steps that use incorrect tools in images and/or text.
Markup Problems
This guide has markup that is either not properly set or is missing from some images.
User-Contributed Guide
This guide is not managed by iFixit staff.
I've found a vacuum in my utility room. Since I almost never use it, I thought it was a good idea to see how it works... So let's go!!
Tools
- Phillips #00 Screwdriver With a long handle, if possible
- Small Flathead Screwdriver
- View:
- Paginated
- Full width
Edit Step 2 ¶
There's several parts in this vacuum:
The tip.
The reservoir which contains the dust and the debris.
The engine (the most interesting part. It will be torn down, don't worry...).
The pedestal (we'll take a look in it later).
And the power supply.
By the way, the reservoir contains 3 parts (from the top to the bottom): the housing, the container and the filter.
And the top if the engine. Nothing interesting... yet. Just notice the power: 4.8V and the intensity of the output.
Edit Step 5 ¶
Now, here is the innards of our lovely vacuum.
More precisely, we can see several wires (to connect the charger light (2), the switch (3), the engine (2), the power wires (2)).
In green: the engine, very noisy but it's the core of the machine.
And in orange: one of the 4 batteries (4*1.2V). They look like C batteries...
Page 1 of 1
