My Problem
Original battery was only lasting less than a day between charges with only "average" use.
My Fix
A piece of cake, but be sure you have the new battery in hand before you start because you will most likely "break" the old battery getting it away from the glue that holds it in place from the factory. Plenty of glue left in the case to hold the new battery in place.
My Advice
If you don't have access to the two special screwdrivers needed to do this, buy the kit also.
0 Comments
