My Problem
The battery in my 5th gen. IPod Nano had reached its life expectancy and would no longer hold or take a charge.
My Fix
Unfortunately during the disassembly process I broke the ribbon on hold switch while trying to remove the battery from the case. Other than that things went well. Needless to say IPod is no longer repairable.
My Advice
Two things-- Disassemble before ordering replacement parts, that way if you break something irreparable your not out the cost of parts you may not be able to use. This is a very difficult repair and should only be undertaken with extreme caution. These parts are very fragile. Having said that I would not hesitate trying again.
0 Comments
