« Back to All Stories
Thermal Paste Replacement on MacBookAir.
by zacshahan
My Problem
I started getting 3 beeps when I turned the machine on. I was told it was a memory problem and that I would have to replace the logic board. I had heard that replacing the thermal paste may resolve the issue, so I tried it first.
My Fix
The repair process went great. I did not need to go through as many steps, as the heat sink is easily removed without removing the battery and hard drive. The repair did not work though. It appears to be an actual memory problem that will require a new logic board.
My Advice
Definitely try this repair first, as it will only set you back <$20. A new logic board runs around $600.
