« Back to All Stories
Replacing a non-working Dell XPS-13 (9360) battery
William Vaughan -
Dell XPS 13
Story image
  • Image #1
  • Image #2
  • Image #3
Dell XPS 13 Battery Replacement
20 minutes
Very easy
My Problem
This is my fairly new Dell XPS 13 (9360), 7 months old. The battery stopped working so I ordered a new one to replace it.
My Fix
Disassembly / reassembly as specified in the IFIXIT article worked exactly as specified. I removed the original battery, opened up the package I had ordered with the new battery, and lo and behold, they had sent me a battery for a different machine, possibly an XPS 15. It was too big and NOT the same battery at all. So I reseated and attached the original battery, reassembled the back casing of the laptop, and voila - it worked and I didn't need to replace it after all. I'm now in the process of swapping the battery sent for the proper model.
My Advice
If I did this again, I'd try removing and reseating the old battery before bothering to order a replacement. In the old days, whether with operating with server / desktop components (which were simple to access and reseat), or checking out the old fashioned click out/in "user replaceable" batteries, this would have been a no-brainer habit. Doing it on a thin, small laptop these days, having to deal with over a dozen tiny screws and tiny sockets and connectors, makes it tempting to skip reseating, assume the component will need replacing, and thereby save at least one disassembly/reassembly cycle. This was exacerbated by this being a fairly new and expensive laptop which is still under partial warranty, so didn't want to screw anything up (no pun intended). Lesson learned ...
Phillips #00 Screwdriver Image
$5.49
3 Comments
Ever since upgrading the BIOS in my system to the latest 2.3.1, the battery life in my system has gone all to ***. I used to routinely get 8 to 10 hours use out of it, and now, if I'm lucky, I get two hours. Tech support has already done an on-site battery and system board replacement, to no avail. I can sit and watch the battery percentage drop in the ePSA screen. System demand supposedly around 2,000 mA, which should yield 30 hours of runtime with the 60 Wh (brand new) battery, but yet goes down to zero in just over two hours. System is also running hot, I notice. All this in the pre-boot diagnostics, so no OS load on the processor.
Anyone else seeing this issue? Last time I updated the BIOS before this was back in April, 2017, which really improved the battery performance.
Any suggestions?
julie - Reply
Any suggestions?
julie - Reply
Any suggestions?
julie - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,260
