Click Image To Zoom
Tri-wing Y1 Screwdriver
$12.95
Product code: IF145-107
Product Overview
The tool you need to overcome security tri-wing screws.
  • Frequently used to deny users access to device internals, getting past a tri-wing is simple with the right tool.
  • Sturdy precision driver with a solid metal shaft, rubberized plastic handle, and spinning top.
  • Fits Tri-wing fasteners found on some Apple laptop batteries that use Apple Tool 922-8991.
  • Fixed-handle drivers make a great complement to a 54 Bit Driver Kit.
  • Upgrade to pro for an ESD safe professional-grade driver.
Also available as part of the Pro Tech Screwdriver Set
Product Details
$5.95 Economy
Condition:
New
Warranty:
60 day warranty
Notes:
Great quality driver. Gets the job done just fine for the average Joe and semi-pros.
$7.95 iFixit
Condition:
New
Warranty:
One year warranty
Notes:
A staff favorite!
$12.95 Pro / ESD / USA
Condition:
New
Warranty:
Lifetime Manufacturer Warranty
Notes:
Top of the line professional made in USA driver with swivel top ESD safe ergonomic handle.
Lifetime Warranty.
Add to Cart »
Stories
My Problem
Clorox Wipe + Trackpad = No Bueno
My Fix
15 mins start to finish, instructions were on point
My Advice
Keep Clorox Wipes away from your trackpad, kids. And if you don't, ifixit is the place to go
My Problem
My Late 2009 Macbook's (the original white unibody) battery died suddenly last summer. I checked with the local Apple retailer but they charged me almost twice the price of a new battery and they also wanted me to leave the laptop for two or three days at their shop. So I checked for a replacement and I remembered that some years ago I had a new iPod battery from iFixit.
Sadly, back then they had no new batteries for my model, so I had to wait and live off the wall charger for a while. That was frustrating because this is my main computer and I work on the go almost everyday, and not every place has a wall charger.
So when I saw iFixit had batteries for sale again I jumped in.
My Fix
It was fairly easy to replace the battery, I just needed the screwdrivers (I had the Torx and ordered the rare Tri-wing) and a bit of patience. My greatest problem was the upper-left side plastic around one screw of the DVD drive, which didn't let the battery gently slip in. But I removed that screw, ditched the plastic piece and the battery wen it like a charm.
Anyway, I hope Apple go back to easy replaceable batteries. They weren't much larger and they were more practical.
My Advice
Have your screwdrivers in place, take care with the plastic piece of the upper left side and don't misspent your money taking this to a shop. With the iFixit tutorial and tools you can do it and save good money.
My Problem
Silly Tri-Tip screwdrivers, lucky ifixit came to the rescue!
My Fix
Excellently
My Advice
Make sure you order the right battery from Amazon, it's too bad that ifixit doesn't stock batteries for newer Macbook Pro's
My Problem
Still waiting for new fan which you have on back order. Hope you really can get your hands on it.
Will let you know how it goes if and when I can fixit.
Thanks
My Fix
Still going
My Advice
Any way to get an update on back orders of the wii fan?
Enlightenment hopefully will follow.
My Problem
The battery in my late 2011 unibody MacBook Pro was failing.
My Fix
The repair went great. I watched the video on the ifixit site and ordered all the suggested tools and the battery. When it all arrived, I jumped right in. The video was so well done that I didn't even need to revisit it. If I had not followed your directions, I never would have ordered the Spudger or Tri-wing screwdriver, which it turns out, were fairly essential.
My Advice
Fix it if you can. A battery in a laptop is a pretty non-threatening repair and a good time to clean out the vents and inside of your laptop shell.
My Problem
Existing 250 GB HDD filling up, and feeling sluggish.
My Fix
Repair couldn't have gone more swimmingly. All the tools to hand, and the instructions simple enough for an idiot (ie. me) to follow. Boot-up a little tense, but needn't have worried.
My Advice
Ok I needed a bit more space, but blown away by the speed increase. Never realised the HDD was such a bottleneck on my system. Should have done it ages ago. Make sure you buy the external adaptor to clone the drive before fitting it and you'll be whizzing along in no time. Oh and amazingly speedy delivery from iFixit (and I live on a remote Scottish island).
My Problem
No problem yet
My Fix
No repair yet.
My Advice
Need more tools for an iphone rebuild.
My Problem
Ma batterie était en fin de vie, impossible d'utiliser mon mac sans qu'il soit branché. J'ai donc choisi de commander une nouvelle batterie sur Ifixit et j'en ai profité pour augmenter un petit peu ma mémoire RAM
My Fix
J'ai suivi les guides de Ifixit et tout s'est très bien passé, j'ai effectué les changements en 20 minutes.
My Advice
Les guides sont très complet et je ne pense pas pouvoir donner de conseils suplémentaires
My Problem
The battery on my mid-2009 MacBook Pro was well past needing to be replaced. It was only holding enough of a charge for 1\2 hour if that much.
My Fix
The replacement took me only about 10 mins since I had been "under the hood" of my laptop on several other occasions regarding upgrades.
My Advice
This is not a difficult replacement for most folks if they have done any upgrades before. There are 10 screws on the bottom cover of the laptop and care needs to be taken to ensure they go back in the same way they came out using whatever method(s) work best for you. The only screws holding the battery in have a tri-wing, or tri-star, pattern and using the Tri-wing Y1 Screwdriver offered through iFixit is a must to ensure you can easily and correctly remove and replace battery. After removing screws a simple unclipping the ribbon cable connecting the battery to the logic board and lifting battery out is all it takes. Installation is in reverse. Work carefully and methodically and all will be fine.
My Problem
My battery was no longer holding a charge.
My Fix
SUPER EASY FIX. Assuming you and work a screwdriver and have the two types needed to do the job, this is as simple as it gets. The small screws on the outside of the MBP that hold the bottom case on can easily be purchased at a hardware store. HOWEVER, there are two internal Y-screws that Apple really doesn't want you to easily be able to remove. iFixit sells a fix for that though. The job was done in less than 10-minutes and my computer now holds a charge like it did when I first turned it on in the Apple store!
My Advice
But the Y-screwdriver with the battery from iFixit. You'll absolutely need it. And just be careful not to lose any of the 10 tiny screws that hold the back plate on your MBP. I didn't have a problem...but those suckers could be hard to find if dropped.
