Click Image To Zoom
Rotary Tool
$49.95
Product code: IF145-105-1
Product Overview
A catch all hacker and modification tool
  • File corners, enlarge holes, etch your name, or many other mods
  • Pen-like use design gives great control.
  • Variable speed 8,000 RPM to 30,000 RPM
  • The heaviest used power tool on the desk of any hardware hacker.
Contains:
  • Rotary Tool
  • Flexible Shaft Extension
  • 40 Assorted accessories
Our 100 Piece Rotary Tool Accessory Set will make sure you are fully stocked with rotary tool bits and accessories.
Product Details
  $49.95 120v / Flexible Shaft
US Only:
This product only ships to US addresses
Condition:
New
Warranty:
6 month warranty
Notes:
As with all power tools, practice extreme care.
Add to Cart »
19 Available
Quantity:
Product Details Edit
Tech Specs ¶
Speed: 8,000 RPM to 30,000 RPM
Chuck: 1/8"
Power: 110VAC
Stories
My Problem
I had dropped a single drop of water into the crack between my computer chassis and the trackpad, this has been the second time (the first time I got Apple to repair it as a "defective" trackpad but the second time I brought it in, they said that the change in performance was not enough to constitute a replacement) and the clicking mechanism and clicking and dragging required excessive pressure to ensure proper function. So time for my own replacement!
My Fix
The replacement was easy and took about 20 minutes. The toughest part was getting the ribbon cable through the weird guillotine structure and onto the logic board. Also, centering the trackpad was not as intuitive as it had seemed.
My Advice
Plenty of light, and some needle tipped tweezers should be added to recommended tools.
