Click Image To Zoom
Phillips #000 Screwdriver
$9.95
Product code: IF145-030
Product Overview
A very small screwdriver, for very small screws
  • Don't be fooled! Many screwdrivers are incorrectly marked as #000, but are too large to unscrew the teensie and delicate 000 screws.
  • High quality steel shaft and hand-tested tip ensure a quality drive, every time.
This size bit is also available as an exchangable bit in our popular 54 Bit Driver Kit , carefully designed to include the most common and often hard to find driver bits used in electronics repair. This driver is also a part of the Pro Tech Screwdriver Set.
Product Details
$5.95 iFixit
Condition:
New
Warranty:
One year warranty
$9.95 Pro / ESD / USA
Condition:
New
Warranty:
Lifetime Manufacturer Warranty
Notes:
Top of the line professional made in USA driver with swivel top ESD safe ergonomic handle.
Lifetime Warranty.
Add to Cart »
Stories
My Problem
cant afford a new replacement phone
My Fix
repair went fine
My Advice
dont need to remove the battery
My Problem
Original home button had a crack down the middle making it difficult to use.
My Fix
Had to play with the home button bit that plugs in a bit to get it in place,, very fiddly little thing! Also one of the screws for the screen wouldn't come out so could just get the screen of enough to get the new home button in. But it works so all good.
My Advice
Don't leave a large amount of time eg. 3 weeks between pulling it apart and putting it all back together ! had this weird bit left over, but the phone works perfectly.
My Problem
My dear lappy's screen has been broken for three years. I've had a PC monitor hooked to it, effectively making it the world's only desk-bound laptop. Frankintosh still ran well, though. I had to do something.
My Fix
"Oh, this is pretty easy, doot doot doo. I mean, if I can do this without--what the !@#$ is an inverter cable?? No. I can't see that! IM FLYING BLIND." *Yosemite Sam noises for 45 minutes* "I friggin hate every !@#$ crap--yes, children dinner, I know Mama is busy dealing with this stupid ugh--oh, hey. It's in. Cool. That wasn't so hard." Then we made love. In the form of various display tests.
My Advice
The spudger on it's own was very little help on seating that inverter (I assume I'm calling that little pink and white bastard its proper name.) A paper clip, bent would have done the trick if I had it, but my final effective solution was to put a weeeeeee bit of stickum (used the bits of tape inside the unit, to be exact) that wasn't TOO sticky to get the plug parked more securely on the spudger. Used the plastic cards as spreaders. Cried out to the gods.
My Problem
Because the home button don't respond anymore and it's really frustrating.
My Fix
The guide was really clear.
The only problem is that after the installation of the button the button respond when you touch it, but don't work when you push on it and sometimes apps close when I'm working on it or the voice function starts.
I'm gonna re-open my iPhone and I'm gonna search the problem.
My Advice
Follow the guide step to step and set notes to the screws on every step.
My Problem
Anciene batterie qui marche pas
My Fix
Très bien ! Et très facile
My Advice
Oui les vidéos
My Problem
Replaced dock connector
My Fix
Perfectly
My Advice
Be very careful with the mic. Take your time. I am so happy that I fixed it.
My Problem
The power button didn't work.
My Fix
First I just ordered the power button, but the problem was the Power and Sensor Cable. I had to pay twice for S&H. (About $70 USD, I live in Mexico city).
The guide is not very clear after step 28. I broke the old Power and Sensor cable because the guide is not clear. Anyway, I was replacing this.
My Advice
If you need to replace the power button because it doesn't work, it is not the power button, it is the Power and Sensor cable. Buy additionally the Earpiece Speaker if you don't want to have additional problems. The adhesive is useless once you take it from the old Power and Sensor cable.
My Problem
they have to fix, because they job fix the mother boards.I order stuffs from you for other trem. they are so happy to get the toools on to fix they boards.
My Fix
The repair when well.
My Advice
no.i dont have photo. to share with. i dont fix the boards. i just order tools for them. sorry.
My Problem
IPhone 4S decide to take a plunge in the toilet. Even though it was quickly dissuaded and removed from said toilet, it still managed to get waterlogged.
My Fix
Opened up the system, removed all components and used a hair dryer to dry all components. Managed to get it all dry before anything corroded.
My Advice
Yes. Iphone 4S is a curious device. But it should be prevented from taking adventures where water is a primary medium.
My Problem
Tenía un iPhone 4 con un problema con el dock ya que no me cargaba la batería. Además la pantalla estaba rayada. Me dieron un iPhone 4 sin liberar y la pantalla estaba mucho mejor que el mío, por tanto decidí que sería más fácil intercambiar las placas lógicas que cambiar los dock y las pantallas.
My Fix
La reparación fue genial, sobre todo gracias a vuestras guías. Enhorabuena por vuestro trabajo. Tanto las guías paso a paso para desmontar el teléfono, como la plantilla para colocar los tronillos que se iban sacando (de mucha ayuda para no perder ninguno) me han servido para tener el teléfono operativo de nuevo.
My Advice
No saltarse ningún paso de los indicados y antes de empezar a desmontar el teléfono, conviene leerse la guía de principio a fin.
