Click Image To Zoom
Phillips #00 Screwdriver
$8.95
Product code: IF145-006
Product Overview
#00 is number one in small electronics repair.
  • Phillips #00 is the most common size screw in small electronic devices.
  • Sturdy precision driver with a solid metal shaft, rubberized plastic handle, and spinning top.
  • Fixed drivers for commonly used screw sizes make a great complement to a 54 Bit Driver Kit for the frequent fixer.
  • Upgrade to pro for an ESD safe professional-grade driver.
Also available as part of the Pro Tech Screwdriver Set
Product Details
$4.95 Economy
Condition:
New
Warranty:
6 month warranty
Notes:
This screwdriver is also a part of the iFixit Epic Screwdriver Set.
$5.95 iFixit
Condition:
New
Warranty:
One year warranty
Notes:
Excellent quality rubber handle screwdriver with swivel top. A staff favorite!
$8.95 Pro / ESD / USA
Condition:
New
Warranty:
Lifetime Manufacturer Warranty
Notes:
Made in USA driver with swivel top ESD safe ergonomic handle. Long lasting construction quality.
Lifetime Warranty. Also available as part of the Professional 56 Driver Set
Add to Cart »
Stories
My Problem
The old fan had worn out bearings which caused lots of noise and bad performance.
My Fix
The switch went well. Took about 30 minutes because the screws were stripped. The comments were very helpful.
My Advice
If the screws are stripped, take a similar size flat screwdriver and put at 45 degrees into the screw so the screwdrivers corner points into he screw, and give a slight tap from each four directions. Then take your Philips screwdriver and try to unscrew. This made it very easy for me.
My Problem
My Macbook Pro 15" unibody battery had went completely dead and I couldn't even power my laptop on when it was plugged in.
My Fix
I was so glad that I bought the tools from iFixit along with the battery. The screwdrivers fit perfectly, and there were 3 Tri-wing screws that needed the special screwdriver, so it was great having everything I needed right away!
My Advice
Get the battery and the tools needed here, that way you are not compromising or running to a store to get specialty tools that are tough to find. I hadn't even heard of a tri-wing screwdriver/screw before! The spduger was also nice because it is plastic and doesn't scratch anything that you pry on.
My Problem
Faulty home button or ribbon cable
My Fix
I have been using my iPhone with a faulty home button or ribbon cable for so long I can't remember. It came to the point a month ago where the button didn't work at all. So I had to assign the optional assistive touch button to access or close apps and that drove me insane. Enough is enough I finally threw in the towel and got online to see if there was a fix and sure enough iFixit popped up. I thought why the !@#$ not. The video and step by step guide seemed simple enough and they even had the right tools. So I placed my order which arrived within a week. Not too bad. Following the video and step by step guide as I thought was easy enough and though the screws were so tiny having the right tools for the job made things quite easy. The only thing I think I did wrong was apply to much force when lifting the front panel off the backing case with the suction cup which came right off without needing to pry the two apart with the tools. Luckily I didn't damage anything. I replaced both the ribbon cable and the button as I wasn't sure which was faulty. Putting things back was fairly simple as well and my phone powered up without any issues. Freakin awesome. Thank you iFixit I am so happy.
My Advice
My advice is don't wait too long to fix your device. I had to use the assistive touch button for so long that now even though with the new home button in place, out of habit I still look for that damned assistive touch button.
My Problem
Clorox Wipe + Trackpad = No Bueno
My Fix
15 mins start to finish, instructions were on point
My Advice
Keep Clorox Wipes away from your trackpad, kids. And if you don't, ifixit is the place to go
My Problem
Super drive would not read disks or skipped. Drive speed would ramp and down and then spit the disk out with an error.
My Fix
Took about 20 minutes to replace the drive. The online guide was very helpful in replacing the superdrive.
My Advice
I would not recommend the Phillips #00 screwdriver Ifixit sells as it did not seat into the screws in the drive (or the back cover) causing the bit on the driver to strip out. I ended up going to Sears and buying a driver. The battery screw driver and spudger worked very well.
My advice, get the proper tools and follow the guide if you need to replace a cd/dvd superdrive in a mac book pro. You can't go wrong as long as you are a bit cautious on the connector handling and follow the directions.
My Problem
Upon visiting the Apple store to complain about the useless power button that mysteriously stopped working on my iPhone, I was told that my only option was to purchase an expensive "out of warranty" replacement. Fortunately, after researching the problem, I chose to buy a repair kit from iFixit instead!
My Fix
The repair process went well, although it was nerve-wracking trying to make sure that I didn't lose any of those tiny screws. It took about two hours, but that included redoing a few steps that I didn't get quite right the first time around. All I can say is thank you so much for the detailed guide! I have a working power button now!!
My Advice
Definitely need a lot of light to see what you're doing. I'd recommend a head lamp. :)
My Problem
I fixed my iPod jack because it would not make connection anymore
My Fix
I broke the glass at the left side while open the I pod now the screen is a bit blurry but further everything works perfect!!!
My Advice
be careful while open it surely witht the glass side
My Problem
So, I'm a Norwegian student interchanging in the Dominican Republic for three months. A week after my arrival I managed to drop my iphone on the ground for the 100th time, and after this it did not want to charge when connected to the charger. The dock connector had been an issue before, but I always got it to work after a few tries. Not this time. I was freaking out, "I'm in Santo Domingo and of course this had to happen now"! But ifixit calmed my nerves. All I had to do was replace the dock connector! It sounded so easy, so I decided to go for the challenge, rather than buying a new phone (I'm a poor student, I want to be environmentally friendly, and I like to !@#$ around with this type of things).
I ordered the parts I needed to fix my iPhone 3G S, and voila! Two days after, they arrived.
My Fix
I followed the video and everything went great! I used less than an hour doing the whole thing, which I was super proud of.
But I made a big mistake with the tiny cables at the end, and didn't connect the #3 cable right, so it didn't recognize the SIM card or the speaker. I was a little bit sick of my phone, so I decided to wait until the next day to fix it. I found a few photos on the internet on how it's supposed to look, and put the cable in its right place, and now my old iphone is as good as new!
My Advice
Take your time, don't rush it! Be sure every move you do is correct.
My Problem
Still waiting for new fan which you have on back order. Hope you really can get your hands on it.
Will let you know how it goes if and when I can fixit.
Thanks
My Fix
Still going
My Advice
Any way to get an update on back orders of the wii fan?
Enlightenment hopefully will follow.
My Problem
Existing 250 GB HDD filling up, and feeling sluggish.
My Fix
Repair couldn't have gone more swimmingly. All the tools to hand, and the instructions simple enough for an idiot (ie. me) to follow. Boot-up a little tense, but needn't have worried.
My Advice
Ok I needed a bit more space, but blown away by the speed increase. Never realised the HDD was such a bottleneck on my system. Should have done it ages ago. Make sure you buy the external adaptor to clone the drive before fitting it and you'll be whizzing along in no time. Oh and amazingly speedy delivery from iFixit (and I live on a remote Scottish island).
