Click Image To Zoom
Magnetic Pickup Tool
$9.95
Product code: IF145-078
Product Overview
Magnets have a wide range of application—from keeping heavily-crayoned papers fastened to smooth-surfaced refrigerators, to finding out which of your friends ate your wrench set. Locate a magnetized tummy today with our Magnetic Pickup Tool.
Great for retrieving small screws from small spaces! Also can be held against side of screwdriver shaft to temporarily make it magnetized.
Product Details
$4.95 Economy / Extending
Condition:
New
Warranty:
30 day warranty
Notes:
The classic "antenna" style magnetic pickup tool. Includes cover that shields magnetic force from sides of magnetic tip, making it easier to feed through tight passages without sticking to other ferrous metals on the way down.
Removable pocket clip, rubberized black handle.
$9.95 Pro / USA
Condition:
New
Warranty:
Lifetime Manufacturer Warranty
Notes:
Of the non-extending type, this USA made machined aluminum handled magnetic pickup tool is great for precision use.
We only use the extending feature of our other pickup tool when working outside on cars or bigger tasks. For at the workbench, we prefer this little guy. The compact size, knurled handle, powerful magnet, and handy pocket clip mean business.
Add to Cart »
Stories
My Problem
The Apple iPhone and MacBook Pro both make it dificult for the user to replace the battery.
My Fix
I started with the iPhone 5 battery replacement. The iFitIt instructions were very clear for the tasks. I used the iFitIt iPhone 5 battery kit with tools that worked fine. Do to my clumsiness I lost one of the small internal screws. A magnetic screw driver would have helped here. Also the screws are so small, a magnetic work pad is a great help. So, I purchased several professional tools from iFitIt including the magnetic project pad and screw driver kits. When I inspected the drivers, none had any magnetic charge for controlling small screws. I purchased a tool magnetized / demagnetizer tool that did the trick. With better tools and a plan I replaced the MacBook battery without issue.
My Advice
Make sure you have a large clean work area. Small screws can be lost if dropped or popped out during disassembly. Magnetic tools and project pad are a must.
My Problem
working for a elementary school with kids using laptops and headphones i always get broken connectors in the headphone jack.
I needed a way to remove the broken end of the headphone connector without taking the whole computer apart. I bought the tweezers set to accomplish this task and they fit nicely in the jack and removed the broken piece in minutes.
My Fix
repair took under one minute
My Advice
saves a lot of time to remove the connector instead of taking the whole computer apart.
My Problem
il était cassé
My Fix
très bien
My Advice
néant
My Problem
make peoples day
My Fix
very good
My Advice
try it your self or bring it to someone that can do it for less than half of the price of the manufacture cost
My Problem
I bought my wife a used iMac that needed some bits and pieces. Hoping that it was the power supply and not the dreaded logic board, I ordered your power supply with overnight shipping. As promised, it was delivered early the next day and came in great shape.
Unfortunately, it was the wrong part for what the computer needs so essentially it's just $150 that I could have put towards the logic board. Worth a shot.
My Fix
Process was fine, I had the computer open already and the piece went in and back out in minutes.
My Advice
If you think it's the power supply, it's not...it's the logic board :(
My Problem
Dead Hard drive- would not boot up.
My Fix
I prepped a large corner desk with a 3 sections of flat shirts and bubble wrap for the glass/bezel/LCD, got a sticky pad and some tape (for homemade blister packs with step # written on them).
My Advice
I did not have a T6 bit, so I was unable to remove the Display connector (I did try with 2 tiny flatheads, but gave up when I mangled them).
Separate the screws by step, I taped the screws from each step onto separate sticky notes, labeled with the step number to keep them organized.
So I did the repair w/o the LCD removed, and had a friend hold it up while I replaced the HDD and reconnected the LCD power.
The magnetizer was a huge help with guiding the screws in.
Make sure to have a can of compressed air- anything trapped between the screen and the glass will be visible. Fortunately, the glass is _really_ easy to remove with the suction cups.
My Problem
Question mark at startup. No hard drive found by Disk Utility.
My Fix
Smoothly, but no speaker audio after rebuild. Need to open it back up and check the cables.
My Advice
double check your connections before putting it back together! Really easy overall. Great guide.
My Problem
Hard disks are expensive these days and I had a spare SSD. I wanted to replace my PowerMac G4 which held the time machine backups and I needed an iTunes server for the Apple TV and to sync the iDevices wirelessly. So I took the cheapest mini which is like 100 times faster than the G4 I guess and installed the RAM and Disks I have.
My Fix
I wasn't very comfortable doing this, I didn't want to mess up my shiny mini, but it all went good. I was astonished at how they managed to cram in those parts while keeping it relatively simple to maintain.
My Advice
It's VERY important to insert the upper hard drive very precisely, otherwise you can't install the antenna plate. The antenna cable is very fragile, don't insert it before you got the drive right!
My Problem
My son spilled coffee that got into his Optical Drive. I replaced the Optical Drive Bezel
My Fix
Went fine.
My Advice
Just follow the good advice from your site.
My Problem
I picked up a used first-gen Macbook Air, spending $460 for a beautiful ultraportable with passable tech specs. I immediately noticed two issues: high heat and a slow hard drive. My MBA put out around 80° C when idling, 100° C under load, and the fan churned constantly at 6200 RPM. Boot times were around two and a half minutes, and even when the OS X desktop finally appeared, another 60 seconds elapsed before my login items were loaded. Something had to be done.
My Fix
The repair process was quick and easy, thanks to expert repair guides published by iFixIt. I found the video teardown especially helpful; MJ's glowing tresses provided me with the confidence I needed to take apart an Apple notebook.
Once everything was disassembled, I was shocked to find that someone on the Foxconn assembly line had applied a entire tube of cheap thermal paste to the exposed dies. The goop had run well off the edge, and all of it had physically deteriorated quite a bit under the high heat. I cleaned everything up, reapplied an appropriate amount of Arctic Silver, installed a 128 GB Sabertooth ZF SSD, and sealed her up. Presto!
My Advice
My system is lightning fast now and actually feels brand new; complete boot in under a minute and idles around 50° C @ 1800 RPM. Any owners of the A1237 should very seriously consider performing a similar repair; I am absolutely loving this laptop now that it's cool enough to put on my lap!
For me, the proper tools made all the difference. In particular, I highly recommend the pro magnetic pickup tool, the Petzl LED headlamp, and the plastic sorting tray. There's a ton of extremely small screws inside the Air, and dealing with them is far easier when you've made the appropriate prep steps.
