Click Image To Zoom
Heat Shrink Tubing Assortment
$6.95
Product code: IF145-076-1
Product Overview
Protects solder joints and wires. 40 pieces in assorted colors and sizes.
Shrink with our Heat Gun or any heat source, such as a lighter.
Recommended for any soldering job or areas where wiring may be subjected to bending or rubbing.
This product is also available as part of the Soldering Workstation.
Product Details
  • Shrinking Ratio: 2:1
  • Length Change Max: - 5%
  • Colors: Black, Red, White, Blue, Clear
  • Diameters: 1mm, 2mm, 4mm, 6mm, 9mm, 12mm
  • Length: 120mm
  $6.95
Condition:
New
Warranty:
6 month warranty
Add to Cart »
36 Available
Quantity:
Stories
My Problem
Haha... there was no problem... or to be more accurate there is not only one specific problem. I fix everything needs fixing all the time. I also love DIY things for my needs. So I better have all available tools handy in my collection.
I am a communication designer and a design thinker. For me tools are much more than just a way to fix things. There are inspirational equipment that lead me to a solution. No matter if I have to fix an iPhone or to create a rotation device for my time lapses, or to find the best way to promote my clients business. There are tools to get your job done and to find a solution for every single problem. Using your tools correctly is a precious skill.
My Fix
Repairs go always very well because every single time there is something new to learn. So it doesn't matter if you succeed or fail, you will always be a winner.
My Advice
My advise is: "try to fix everything you can, because at some point of your life you may find that to repair is the only solution you have for some precious things, and then you will appreciate the lessons you have learned so far in your fixing things history".
There is a story behind every attempt to correct things and make them work, and this story is not only a technical one.
To fix a broken device is like to give life to something. It inspires you and increases your self confidence. It shows you that you are able to make things work and this may as well apply to other parts of your life.
Thanks for your time
