Click Image To Zoom
Desoldering Braid
$4.95
Product code: IF145-079-1
Product Overview
Desoldering Braid is great for removing excess or unwanted solder. Important for battery installs that require soldering or removing components from a circuit board. Works great with our Soldering Kit, but it's also a part of our Soldering Workstation.
Product Details
  • Length: 5 Feed / 1.52 Meters
  • Type: Copper braid with flux
  $4.95
Condition:
New
Warranty:
6 month warranty
Add to Cart »
50+ Available
Quantity:
Product Details Edit
Desoldering Wick
IF145-079
The braided Copper in a desoldering wick absorbs solder from pre-existing joints. Removing old solder simplifies the task of soldering new components to thru-hole and surface mount joints.
Stories
My Problem
I have been an electronics repairman for years and just began a new journey to open my own wireless repair facility and needed a few tools. I came across an article about another cellular repair shop using IFIXIT.com tool kits and when I looked into it I found the kits had exactly what I was looking for at the right prices.
My Fix
The tools work excellent and are made of good quality materials. I have not yet run into a wireless device the toolkit does not have the right tool for. Thank You for an excellent product.
My Advice
Use professional grade tools from a professional company like IFIXIT.com.. Great customer service, resources and materials!!!
My Problem
I teach an ipad repair class to a group of 8th graders. This order was just to replace some tools. We are going to give the isesamo tool a try. Our best tool so far has been a metal spudger. It has a triangular end an a curve spatula end. You sell one that looks like it but the spatula end is to dull to get between the glass and bezel. I hope the isesamo tool does the trick. We will repair a couple hundred iPads this year and your tools are indispensable.
My Fix
We have not had a chance yet to give the tools a run. I am sure they will be just fine.
My Advice
Find a supplier of sharper metal spudgers
My Problem
The battery had been failing for some time, getting weaker every day at the end.
My Fix
Not much to tell. I followed iFixit's guide for replacing the battery in a 1st gen iPod Touch. Each step went just as the Guide stated. And I succeeded!
My Advice
Just follow the Guide. This is my third use of iFixit's guides for diverse electronic repairs. And each time the guide lead me to success.
My Problem
I purchased the tools to use at my volunteer "job". Our group of GE retirees gifted more than 650 donated computers last year. All computers and other equipment are given to any qualified non-profit organization that requests one or many computers. Read about our group and the process for requesting computers at computerrehab.org. The 54 piece Driver Kit is a second kit that I own. Although there are duplicate bits in the two kits, there are many bits in the second kit that are not included in the original kit.
My Fix
Most of our repairs are successful, having the right tool makes the access and disassembly much easier. Our failures and obsolete equipment end up being stripped and recycled. We raise several thousand dollars a year from recycled copper, aluminum, motherboards, CPU's and memory boards. Most of the dollars are used to purchase hard drives, printer cartridges, batteries and tools.
My Advice
Any repair job is much easier when the right tool is available. i believe that one should buy the best quality tool that is affordable.
My Problem
the ground connection was broken and l put it in the shop to get the screen fixed and the shield the up by the display chip was gone the iphone work and l could hear sound but no picture and l looked up the iphone connection and the shield and the connection was gone so l have been look for the old iphone logic board
My Fix
I am still look for a board or iphone with water damage and will try to remove the ground connection and repair it
My Advice
find a good repair computer
My Problem
I phone 1 Would not take a charge (number of time)but several weeks later after allowing to drain it took a full charge and have not yet therefore changed the battery. Have received all items, excellent service next day delivery. Thank you.
My Fix
See above
My Advice
See above
My Problem
My son has had his iPod touch for about 2 or more years and the battery was at a point that the unit would not hold a charge for very long. He uses this thing continuously and it is important to him. I had seen on iFixit that you had a replacement battery and the tools/instructions on how to do it. I am an electrician and a electronics enthusiast so ordered up the tools and replacement battery and got it done
My Fix
Did the repair in very short order, the instructions on the iFixit website guiding me all the time and the repair was a success, i am a hero because of you guys!
My Advice
iFixit ROCKS!
My Problem
I am not happy with the pricing on the the existing pressure sensitive graphics tablet/monitors so I have been experimenting with making my own.
My Fix
I'm not sure what I'm doing so this may be a disaster but 1) I will learn so much from the process and 2) I may end up with an awesome homemade version of a Cintique.
My Advice
None to offer yet
My Problem
orig. battery was weak, didn't hold much charge
My Fix
The first battery from iFixit resulted in a phone that appeared bricked. Phone would start but not boot, not able to restore or leave recovery mode. DFU mode could be achieved but nothing else.
Mike picked up my comment on the "meta" site and suggested I send a note to support@ifixit.com, which I did. I was sent a new battery without asking for one, nor anything else. When I asked why this was I was told the battery or soldering job might have been bad ...
The second battery arrived, I removed the first replacement and reinstalled the phone's original battery --- it booted up perfectly. I removed that and installed the new, second battery from iFixit and all's well.
My Advice
If you fear the worst, reinstall your old part and verify you can get back to the original condition that required a fix (if applicable, of course.)
And go slow with the back cover. I bent it where it meets the antenna cover and now doesn't close completely.
run4da's Story Photo #159336
run4da's Story Photo #159335
run4da's Story Photo #159338
My Problem
Battery was not holding a charge
My Fix
I was definitely scared about attempting this project. The first challenge (prying open the antennae cover) was very daunting. I've uploaded a pic for illustration purposes - A is where I started to pry open the case, and B is the correct location for prying open the start of the back cover. Once I got that part off, my confidence became stronger as I continued. I must say this is a difficult task, but is doable with steady hands and calm nerves.
My Advice
Buy all the suggested parts and tools, follow along with the online guide ( I used my hp tablet ). I also think that the guide needs to be more explicit. Prying of the black part n this device is the hardest, once you get it off the rest is a piece of cake.
Related Questions
