Click Image To Zoom
PC2-6400 2 GB RAM Chip
$34.95
Product code: IF111-034-1
Product Overview
Adding RAM to your computer can provide a significant performance boost.
Although Apple reports the maximum RAM for the Early 2008 iMacs and Mid 2009 MacBooks as 4 GB, you can actually install up to 6 GB in these machines. These computers have two available RAM slots. This 2 GB RAM chip can be combined with a 4 GB chip, yielding a total of 6 GB of RAM. Although 8 GB will physically fit, the system will be unstable if 8 GB is installed.
Compatibility
  • 2 GHz (Early 2009) Core 2 Duo MacBooks
  • 2.13 GHz (Mid 2009) Core 2 Duo MacBooks
  • 2.4 or 2.66 GHz (Early 2008) 20" iMacs (EMC No. 2210)
  • 2.8 or 3.06 GHz (Early 2008) 24" iMacs (EMC No. 2211)
Product Details
  • Height: 1" (Low Profile)
  • Type: 200 pin, DDR-2
  $34.95 New
Condition:
New
Warranty:
6 month warranty
Add to Cart »
11 Available
Quantity:
Replacement Guides
MacBook Core 2 Duo
Difficulty: Easy
Compatibility
iMac Intel 20" EMC 2133 and 2210
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
iMac Intel 24" EMC 2134 and 2211
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
MacBook Core 2 Duo
2 GHz (Early 2009)
2.13 GHz (Mid 2009)
Stories
My Problem
After owning an iMac for 5-6 years, the hard drive had filled up, and the times required to boot and open applications were very slow.
My Fix
Ordered up the parts for RAM and hard drive upgrades from iFixit and followed the online instructions, referring back to the video guides as necessary. This took me essentially a full working day -- not the replacement of the physical parts, but the restoration of the software/the desktop. The steps involved in the latter were not intuitive and took lots of poking around the Internet to find what I needed. Nonetheless, I got there in the end.
My Advice
As you go through any procedure in iFixit, follow instructions closely, improvise where you feel you can get away with it, and use Google frequently as you restore your system after replacing physical components.
My Problem
Computor slow had just installed new hard drive, now was the time to finish the upgrade
My Fix
Easy like changing a light bulb
My Advice
Straigt forward current info I will use this site for any of my needs.Thank You great customer sat.
My Problem
Battery was dying, computer was slow. Don't have the money to get a new one just now.
My Fix
Easy with the guides, very quick.
The battery is not exactly the same color of white plastic as my computer, but it's all right, it's an old model A1181.
My Advice
none
My Problem
The original 320GB hard drive completely died after 5 yrs of nearly continuous service. Found the ifixit site with great instructions and the necessary parts.
My Fix
The parts arrived in a few days and the repair was easy and fast. Has the ufixit guide on my iPad and followed the step by step instructions. Finished in less than one hour. Everything booted up fine and was able to reinstall from my Time Capsule.
My Advice
Read the entire repair steps first before proceeding to make sure you have everything.
My Problem
My iMac was old and running slow
My Fix
Very good with the Guides
My Advice
Don't over tighten the screws!!
My Problem
Too many users, not enough memory.
My Fix
Easy. Did it in-between cooking dinner, one screw and the plate comes off. Insert the memory and it goes back together. 5 minutes start to finish including shutting down and restarting the iMac.
My Advice
Could have not been easier.
My Problem
freezing do to lack of RAM
My Fix
Good
My Advice
have enough ram
