PC2-5300 1 GB RAM Chip
$14.95
Product code: IF111-000-1
Apple Part #: 661-3867
Product Overview
Professional sprinters know that winning the 60 meter dash requires the right combination of muscular strength, adrenaline use, and strategically placed moving sidewalks. Dash to the finish with our speed-enhancing PC2-5300 1 GB RAM Chip today.
Adding RAM to your computer can provide a significant performance boost. Install in matched pairs for increased performance.
PowerBook G4 Aluminum 1.67 GHz high-resolution machines originally shipped with PC2-4200 RAM, but this chip can be installed instead of PC2-4200 RAM and is fully compatible.
Compatibility
  • All MacBooks and MacBook Pros (excluding Air and Unibody)
  • 1.67 GHz High-Res (1440x960) 15" Aluminum PowerBooks
  • 1.67 GHz High-Res (1680x1050) 17" Aluminum PowerBooks
  • 1.5, 1.66, 1.83 or 2 GHz (model A1176) Mac minis
  • All 17" Intel iMacs
  • 2, 2.16, 2.33, and 2.4 (EMC 2133) GHz 20" Intel iMacs
Product Details
  • Height: 1" (Low Profile)
  • Type: 200 pin, DDR-2, 667 MHz
  $14.95 New
Condition:
New
Warranty:
6 month warranty
Add to Cart »
8 Available
Quantity:
Replacement Guides
iMac Intel 17"
Difficulty: Easy
iMac Intel 24" EMC 2111
Difficulty: Easy
Mac mini Model A1176
Difficulty: Moderate
MacBook Core 2 Duo
Difficulty: Easy
MacBook Core Duo
Difficulty: Easy
Compatibility
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz (EMC No. 2105)
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz
2.8 GHz (EMC No. 2134)
1.5 GHz (Core Solo, A1176)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo, A1176)
MacBook Core 2 Duo
1.83 GHz (Core 2 Duo)
2 GHz (C2D, Late 2006)
2 GHz (C2D, Mid 2007)
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.16 GHz (Core 2 Duo)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
MacBook Pro 15" Core 2 Duo Model A1211
2.33 GHz (Core 2 Duo)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 15" Core Duo Model A1150
1.83 GHz (Core Duo)
2 GHz (Core Duo)
2.16 GHz (Core Duo)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
Stories
My Problem
No enough default RAM (512MB only).
My Fix
Very well.
My Advice
No.
My Problem
1GB -> 2GB Upgrade
My Fix
Repair went well. Very Easy following iFixit directions
My Advice
Having and using the correct tools makes the job go smoothly.
My Problem
Simply to slow
My Fix
It went just fine!
My Advice
I used the guide
My Problem
My 2006 Mac mini was still running tiger os 10.4.11. Unable to use many newer applications, update web browser, sign up for nest account for my newly installed nest, etc because computer was too slow. Also it would stall out constantly, freeze up and quit unexpectedly. Needed more memory and new OS. Local repair guy recommended I just buy a new computer.
My Fix
Overall went very well. Taking the cover off was still difficult even with the isesamo. Actually ended up bending the isesamo badly in order to pop the case off. But once it was off there was no problem detaching and unscrewing things. RAM came out and installed easily enough. Putting things back together was a little trickier. Reinserting the thermal sensor cable was a little difficult but I finally got it. Three of the four screws that came out went back in easily but I was unable to get the 4th in and get it to "grab" anything. After several attempts I finally gave up. It seems to be fine with the 3 screws. I'm hanging onto the 4th to try again later. Afterwards I installed snow leopard and that also went well. Computer seems to be running much smoother now. No problems have been detected so far.
My Advice
I had been too scared to attempt opening my mac and trying to repair myself fearing I would break it or make it worse. Now I'm glad I saved my money and upgraded myself because it wasn't as difficult as I thought.
My Problem
to little rams to upgrade the computer to OS-X lion
My Fix
Installing a new 2 GB RAM chip i addition to the existing 1 GB RAM chip using the guide went smooth, to the MacBook Pro 15 model 1211
My Advice
read about possibilities for upgrading.
Follow the instruction
My Problem
The Mac Mini needed more RAM.
My Fix
It was touch and go, but I used my old rusty putty knife to get the mini open and install the RAM. Using the repair guides I followed the procedure step by step. When I powered it back on, I was amazed to see 2 GB functional!
My Advice
This procedure is not for the electronically uninitiated. But I felt if the girl in the video can do it, so could I!
My Problem
Dead hard drive on older macbook 2.1. Tired of putting dead computer equipment in storage until next recycling effort. Decided to spend a little money and see if I could repair/upgrade laptop.
My Fix
Perfecto. Installed a new SSD drive I already had (sorry next time buying it at ifixit). Then bought new hard drive cable (macbook didn't recognize new hard drive) and added RAM. Used all the how-to resources on ifixit website. Miraculously, everything worked and the macbook is extremely fast and working perfectly. The ifixit guides were very accurate and helpful.
My Advice
Not sure if this is good advice or not. Before doing install of new hard drive, connect it to macbook as an external drive first to see if the laptop recognizes it. If it doesn't, may need a new cable as I did. BTW, I had removed old hard drive and had my work IT guy confirm that it was dead.
alabirsa's Story Photo #179573
My Problem
The "kernel panic" was coming always when I was trying to reinstall OSX
My Fix
I had the "kernel panic" and it took some time to find out it was a bad RAM that I have to replace.
My Advice
I had to find out the solution.
My Problem
I had an old MacBook that sat unused for years. My son wanted to flex his programming skills in developing apps, and I thought it would make the perfect platform. It used to seize quite a bit in the day, and remember leaning it was the drive. It also came with 512 megs of RAM. Not much.
My Fix
I've never had such a hassle free experience. We literally yanked out the old RAM and drive, popped the new ones in, installed the new O/S, and it all went without a hitch.
My Advice
None. ifixit covered everything soup to nuts. If you have an old Mac, these upgrades are a snap.
My Problem
Need to upgrade
My Fix
Good no problem at all was complete in 15 minutes.Thanks to your staff
My Advice
Follow fix it directions
