Click Image To Zoom
MacBook Unibody (Model No. A1278)/MBP 13" (Mid 2009) Unibody Fan
$49.95
Product code: IF160-017-1
Apple Part #: 661-4946
Product Overview
Make sure you have identified your MacBook correctly. You can use our Identify Your Mac.
If it weren't for wind, models would look less dreamy in convertibles, windmills would get really bored, and Linka would be out of the Planeteers quicker than you can say "Heart!" Guard your MacBook with gust today with our MacBook Unibody (Model No. A1278)/MacBook Pro 13" (Mid 2009) Unibody fan. (You might be out of breath after saying that, but your fan won't.)
Includes fan and surrounding metal bracket.
Compatibility
Identify your Mac
  • 2 or 2.4 GHz (Model No. A1278) Unibody 13" MacBooks
  • 2 or 2.4 GHz 13" Unibody MacBook Pros
Product Details
  $49.95 New
Condition:
New
Warranty:
6 month warranty
Add to Cart »
50+ Available
Quantity:
Install Videos
Replacement Guides
MacBook Pro 13" Unibody Mid 2009
Difficulty: Moderate
MacBook Unibody Model A1278
Compatibility
2.26 GHz (Mid 2009)
2.53 GHz (Mid 2009)
2 GHz (A1278)
2.4 GHz (A1278)
Stories
My Problem
CPU temperatures had started to spike on my laptop (80C or higher) while doing mundane things at low percentages of CPU, and fan didn't spin up to cool the machine. Apple did diagnostics, said all was well. Temperature Gauge Pro detected a problem with fan, however, so I ordered a replacement to see if that would fix the problem.
My Fix
Great. Took about 20 minutes, fan works, temperature profile back to normal, laptop is happy again.
My Advice
You should use a #000 Phillips screwdriver, not #00. The screws are easy to strip, and #000 fits better, makes it easier to get tight screws loosened without stripping screws. And, if you stripped a screw with #00, you still might be able to get it out with #000. Also, make sure to pay attention to the shape of the 7 smaller screws in the bottom of the laptop. 4 of them have a larger diameter neck above the threads. Those go in the four holes along the bottom of the case (the edge opposite the hinge, where you open the laptop).
My Problem
Loud noises prompted me to take my Macbook Pro to the Genius Bar. They wanted to keep it for 3+ days to replace the fan, at a pretty significant cost. I happen to be blessed with a very smart teenager who cut his teeth on taking Mac's apart. Quick order on iFixit, an even faster delivery, and voila!
My Fix
Simple simple simple. Took my son about 15 minutes start to finish. Great tutorial. I'm a first time ifixit customer, and you've got me for life. Thanks!
My Advice
Follow the tutorial exactly, and if you're at all hesitant, seek out a smart neighborhood teenager to do the job for you.
My Problem
battery only lasted about an hour fully charged, and it the whole computer would rapidly overheat.
My Fix
A bit scary. The battery went in without a hitch, but when removing the old fan, the socket ripped off of the circuit board. I ended up soldering the individual wires back on. Now it works great though! 5 hrs battery life and fan works much better.
My Advice
BE CAREFUL WHEN REMOVING THE FAN CONNECTOR!
Sondre Selnes's Story Photo #257497
My Problem
The fan on my MacBook Pro was reaching its end. It was terrible noisy ! I was in the middle of a programming project for the iPhone and making video guide for the new software, when the fan of my computer broke down. I had to stop all recording (Big Blue Yeti mic, ScreenFlow recording...).
My Fix
The video guides from iFixit are excellent and their service is perfect! Now the new fan is in place in my Macbook Pro and I can again continue my work with the recordings - and - listen to radio and music (Madredeus from Portugal and Maxim from Russia, are my favorites!).
With iFixit video guides and a new fan from iFixit it went perfect ! It took about 5 minutes to repair.
My Advice
Shop at iFixit, their service- and products are fantastic! I bought two fans, so that I also have one extra for later use. The shipping and service are very fast - only 6 days to mid-Norway !
I recomend iFixit because of their great service-and products.
Camera tip: Leica V-Lux 4 and Leica D-Lux 6 are two fantastic compact cameras. I plan to buy one of them. Leica quality is the very best. Photo above is from Åfjord, Norway, made by a Nikon camera.
My Problem
The old fan had become noisy - bearings worn out probably. (After taking it out, I could see the blades spun crooked.)
My Fix
Pretty easy repair, only 3 internal screws. The connector is a little tricky since it's so small, you tend to think you're gonna break it. Go slowly around the edges and it'll come out.
My Advice
I'll second something someone else said about the new fan seeming much higher quality - spins much easier, though it seems to be exactly the same part. Could be just that the old one was, in fact, screwed up, and it once spun the way the new one does.
My Problem
My fan was making a god awful sound whenever my macbook would start heating up. This had been happening ever since an unfortunate crepe experience where I managed to spill lemon-sugar syrup into my keyboard.
My Fix
The repair was incredibly straight forward. It was a very minimal risk procedure.
My Advice
Be prepared for a lot of dust if you haven't opened up your macbook since purchasing.
My Problem
The blades on the original fan had broken and was making a lot of noise when it spun up.
My Fix
I've opened the computer many times before so the repair was a piece of cake. ~5 minutes in total.
My Advice
My Problem
My old fan broke so i had to replace it.
My Fix
The repair was very easy, fan had only 3 screws and the spudger helped me to remove the cable. The tools i ordered were just as described and made for this task.
My Advice
New fan from ifixit is very good (low noise). Only downside was Estonian customs, i had to pay them extra 35$
Sorry for bad english.
My Problem
The fan became too noisy. Cleaning it did not help.
My Fix
Finally it was pretty easy to replace this part on my MacBook Pro following the guide provided by iFixit.
My Advice
Th only thing you have to get to do this job is the good kind of screwdriver. This was not a problem since I had already have to get inside a Mac mini a few months ago.
My Problem
A while ago my 13" MacBook Pro from 2009 started making a weird noise. I quickly discovered that it was the fan that was broken (both by the noise it gave and also by checking the fan speed in an application).
My Fix
I ordered the spare part from iFixit.com and got it shipped to Europe in just 4 business days. The forecast of the shipping said 3 weeks so I was really happy.
The repair was super easy. Just open up the back of the laptop. Loosen two screws on the old fan. Unhook the cable. And do the reverse for the new fan. I thought I had to check the guide but it was easy enough to do it without the guide.
My Advice
