Click Image To Zoom
MacBook Pro 15" Unibody (Mid 2010/Early 2011/Late 2011/Mid 2012) Left Fan
$49.95
Product code: IF161-059-1
Apple Part #: 922-8703
Product Overview
Make sure you have identified your MacBook Pro correctly. You can use our Identify Your Mac.
If your screen is facing you, this is the fan on the left side of the machine. Includes fan and surrounding metal bracket.
Compatibility
Identify your Mac
  • All Mid 2010 15" Unibody MacBook Pros
  • All Early 2011 15" Unibody MacBook Pros
  • All Late 2011 15" Unibody MacBook Pros
  • All Mid 2012 15" Unibody MacBook Pros
Product Details
  $49.95 New
Condition:
New
Warranty:
6 month warranty
This product is out of stock.
Notify me
Replacement Guides
MacBook Pro 15" Unibody Early 2011
Difficulty: Moderate
MacBook Pro 15" Unibody Late 2011
MacBook Pro 15" Unibody Mid 2010
MacBook Pro 15" Unibody Mid 2012
Compatibility
2 GHz (Early 2011)
2.2 GHz (Early 2011)
2.3 GHz (Early 2011)
2.2 GHz (Late 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2.4 GHz (Mid 2010)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2010)
2.3 GHz (Mid 2012)
2.6 GHz (Mid 2012)
2.7 GHz (Mid 2012)
Stories
My Problem
my macbook has just turned 3 and the fans actually started making noise at 2.5 years but tolerable took in to apple 2 weeks before applecare expires but they find nothing...
My Fix
i ordered the fans from IFIXIT replaced them within 15 minutes and now i have silence
My Advice
this is such an easy replacement and now my macbook is good as new.
My Problem
My MBPs left fan was really noisy.
My Fix
pretty simple - opened up the case, took some screws and a cable out, put the new fan in. closed it. took about 10 minutes.
My Advice
as always - use the right tools and you won't get stuck.
My Problem
My 2010 MBP's battery wasn't holding much of a charge anymore. The left fan also wasn't working.
My Fix
The fan and battery were super easy to replace with iFixit's guides. My laptop is now being cooled properly and the battery is lasting just as long as it did when I first got my MBP. The only difficult part was getting the battery plugged in properly.
My Advice
Be sure to get the battery connector pushed fully into its socket! This task was quite challenging for me and took about 10 minutes worth of carefully positioning and applying appropriate pressure. It appears that this version of the battery (non-Apple) is more sensitive about how it's positioned than the original battery.
My Problem
Laptop was running hot. I found out that the left fan was dead. A quick search landed me on iFixit with great instructions and pictures of how to remove and replace the fan.
My Fix
Fan replacement took about 10 minutes. 5 for the actual replacement, 5 to clean out all of the dust that has collected inside the laptop over the years.
My Advice
The inside of the Mac isn't as scary as I imagined. Get in there and play around.
My Problem
I fixed it because it was louder than a freight train and it was making me crazy.
My Fix
Holy mackerel, that was stupidly easy!! Don't be scared, just do it. I'm all thumbs and I did it. You can too. TRUST these people!
My Advice
My eyes aren't what they used to be. I definitely needed my glasses to see the tiny screws. A white sheet over the table helped, as did a really bright light. But that was the worst of it. This could not be a simpler thing to do.
My Problem
the fan was causing 70 db noise.
My Fix
i unscrewed the back and removed the faulty fan and replaced it with the new one.
My Advice
thanks!
My Problem
This MacBook Pro is a workhorse and on for 20 hrs a day powering an external monitor. The fans finally started sounding like meat grinders.
My Fix
Repair was easy! I used a tool kit I ordered with the parts because I didn't have a #6 torx bit.
My Advice
Definitely make sure you have the right tools.
My Problem
I thought for a long time that it was the hard drive that was the problem. A technician suggested it might be the fans making the noise. It sounded more and more like the right thing. I ordered both fans just to be sure to eliminate the problem either it was the left or the right fan.
My Fix
Followed the webinstructions and the sound went away
My Advice
Easy fix to potentially critical problem
My Problem
The left fan started to sound like a lawnmower, nearing death...
My Fix
Followed the instructions on ifixit.com and was done in 10 minutes, easy peasy
My Advice
Make sure to buy the weird star shaped screw drivers that you will need, before trying to open up your mac.
My Problem
Left fan on my macbook pro has was going out. Made the absolute worst noise I have ever heard a laptop make. Was also causing my computer to run hotter than normal due to the fan not spinning properly. I finally decided to fix it after the noise went from a slight rumble to a death scream.
My Fix
The repair was very easy. Took me all of ten minutes to replace.
My Advice
The only thing I can think of in the way of advice is just be sure that when removing the connecter for the fan be sure to pull it straight up.
Also after removing the back cover and seeing all the dust collected in the fans and dust traps I would recommend hitting it with some air duster maybe once a year or something like that.
