Click Image To Zoom
MacBook Pro 15" (Model A1260) Left Fan
$49.95
Product code: IF185-113-1
Apple Part #: 922-8358
Product Overview
Make sure you have identified your MacBook Pro correctly. You can use our Identify Your Mac.
If your screen is facing you, this is the fan on the left side of the machine. Includes fan and surrounding metal bracket.
Perspiration is the body's method for regulating its temperature, highlighting its muscles, and ingesting cotton candy clothing. Sidestep sweat for stormy gales today with our MacBook Pro 15" (Model A1260) left fan.
Compatibility
Identify your Mac
  • 2.4, 2.5 or 2.6 GHz (Model A1260) 15" MacBook Pros
Product Details
  $49.95 New
Condition:
New
Warranty:
6 month warranty
Add to Cart »
18 Available
Quantity:
Compatibility
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
Stories
My Problem
At least the left fan on my Macbook Pro Early 2008 (1260) -- which was otherwise in great condition, started whining. Pretty embarrassing in a meeting. Since I had to open up the case anyway, I decided to to replace both fans. Purchased both from iFixit, which arrived in two business days.
My Fix
Follow directions in the iFixit guide carefully, and the repair will be easy, even though categorized as "moderate" in difficulty. It took about 1/2 hour to replace both fans (I intentionally made it a "slow" repair). The replacement fans are almost noiseless, and the repair cost ($50 per fan) was well worth the investment.
My Advice
Take your time, and make sure to separate out the various screw types in sequence to their removal (it makes putting everything back together very easy). Be very careful (for this model MBP) about *not* mistaking the the HDMI port screw hole for the proper case screw hole. I did this in my first repair (HD replacement) and I couldnt' remove the screw...it finally worked its way out on its own (and fell to the bottom of my case). I took to heart iFixit's caution to be very careful to not lift the keyboard too quickly (you'll easily damage the keyboard/logic board ribbon cable) --- and was glad I did. Thanks, iFixit for a great repair guide. I'd highlight with yellow circles rather than red against a dark background, Otherwise, perfect.
jordikanal's Story Photo #314254
jordikanal's Story Photo #314252
jordikanal's Story Photo #314253
My Problem
Both fans of my laptop started doing several noises often, until one day the left fan didn't stop doing a loud noise similar to a running bike when it isn't pedaled.
I decided to open my laptop and clean it properly, not only the left fan, but also all the laptop. Once I finished, I run the laptop again, but my problem wasn't solved.
I looked online for any solution and I found iFixit. Best website ever! First of all I tried to repair my fans, but they got worse. Their bearings were broken and nothing could be done. I tried to file down the fan cases in order to see if the noises were made by the fan blades scratching the cases. This operation ended with the right fan doing a noise that reminded me to a chainsaw cutting an iron plate.
There was nothing left to try but replacing the fans. So I ordered them.
My Fix
Great! I followed the guides and in less than 15 minutes my laptop was running perfectly.
My Advice
Do not hesitate in trying to repair your device. Do not resign yourself to buy a new device or to accept the outrageous cost that the official repair department impose you.
Try to repair it by yourself. Take a look to the guides that are already written, test your device, be sure of what the problem is, order the components if necessary and get on with it. I'm sure it'll be easy, fun and cheap!
My Problem
The left fan was making grinding noises and the left side of the laptop started getting very hot.
My Fix
Everything went smoothly. The directions were clear, and the parts went in place without a problem.
My Advice
If you have any doubts, print out the instructions.
My Problem
The left fan in my MBP sounded like a jet plane taking off. It needed to be replaced because I could no longer use my laptop in public.
My Fix
Very easy.
My Advice
The fan and another similar connector push in, they don't slide in.
My Problem
The right side fan on my Mac laptop A1260 was screaming like a pack of 10yr old girls and driving me and the family crazy.
My Fix
Daunting at first seeing as I needed to remove the whole top half of the laptop and it had connections I was not familiar with, but the how to guides here on ifixit were excellent and made the whole experience a pleasure. In fact, while I had it opened, I went ahead and put in a larger HD with the money I saved from not having to pay repair labor.
My Advice
It is definitely easier than you think. The Spudger tool is a no brainer, get it and use your screwdriver for something else....like screws.
My Problem
The fan was extremely noisy, so much so that you could hear the laptop operating from other rooms in the house. No choice, then - the fan had to be replaced
My Fix
The install guide was very detailed and helpful. The only criticism was that when it came to putting everything back together, there were a couple of challenges that had not been described. The connector for the iSight camera was not straightforward to replace, and it took the best part of ten minutes of fiddling before I got it re-connected. It seemed that the upper part of the connector would not bend back to the correct angle to let it slide into place, and the connector itself seems quite fragile. Some guidance on the best / right way to handle this item would have been welcome. Total install time, start to finish, about 45 minutes.
My Advice
Make sure you pull the tape with the iSight wires attached well away from the work area so that you can properly orient the connector back into its receptor.
My Problem
fan and drive died
My Fix
having built computers, made repairs, this was simple.
My Advice
iFixit provides you with pictures that are worthless without an internet connection and an extra computer to view while you fix yours. Nothing ventured is nothing gained. Look at pictures; figure it out; go for it.
My Problem
Seriously noisy fans.
My Fix
Easier than expected.
My Advice
Go Slow, be organized, have a good space available with all tools, parts and snacks within reach.
My Problem
My Macbook Pro gets a lot of use and the fans were finally reaching a point of strain where they were almost ineffective.
My Fix
Repair went flawless; the teardown guide was very accurate in stepping me through with disassembly. I didn't run into any issues at all since I have replaced the main board before so I was familiar with the components already.
My Advice
Be very careful when prying up the keyboard and trackpad panel from the main body so you don't jerk it upward and pull the connector off the main board.
My Problem
the fan was noisy and there was no battery life in the five year old Macbook Pro 15"
My Fix
okay, except for a issue with the connector to the HD. Had to reopen the machine a second time to firmly set the connection
My Advice
keep the economy running, just buy new
Related Questions
1 Answer
0 Score
cooler fan emc 2198
0 Score
Need ID help to determine correct part order
