Click Image To Zoom
MacBook Battery
$99.95
Product code: IF186-009
Apple Part #: 661-3958, 661-4254, 661-4413
Product Overview
  • Replacement laptop battery rated 4900-5200 mAh and 55 Wh
  • Apple's Model # A1185
  • Fits in 13.3" MacBooks (Not Unibody or Air)
Compatibility
Identify your Mac
  • All 13.3" MacBooks (excluding MacBook Unibody and MacBook Air)
Product Details
  • Model: A1185
$99.95 White / New
Condition:
New
Warranty:
6 month warranty
$109.95 Black / New
Condition:
New
Warranty:
6 month warranty
Add to Cart »
Replacement Guides
MacBook Core 2 Duo
Difficulty: Very easy
MacBook Core Duo
Compatibility
MacBook Core 2 Duo
1.83 GHz (Core 2 Duo)
2 GHz (C2D, Late 2006)
2 GHz (C2D, Mid 2007)
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz (Core 2 Duo)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
Stories
My Problem
Battery was starting to bulge and the adapter stopped working due to fray.
My Fix
Very quick to change. Also purchased a Fray Fix to hopefully extend the life from this adapter.
My Advice
Fray Fix: http://www.thefrayfix.com/
My Problem
Increased the memory and replaced battery. Not able to find parts at the Apple store
My Fix
Perfect. The repair guide was really helpful
My Advice
No
My Problem
Battery was dying, computer was slow. Don't have the money to get a new one just now.
My Fix
Easy with the guides, very quick.
The battery is not exactly the same color of white plastic as my computer, but it's all right, it's an old model A1181.
My Advice
none
My Problem
Old battery had finally died so decided to replace and while we were at it, doubled the Ram.
My Fix
Smoothly.
My Advice
Laptop works like new, upgraded OS, etc. would recommend to anybody. Thanks
My Problem
The battery on my MacBook was bulging which was putting pressure on the trackpad, causing it to "stick." It eventually got so bad that it was impossible to use. Very annoying.
My Fix
Easy fix--just removed the old battery, and slipped in the new. Took less than a minute, start to finish.
My Advice
This was an incredibly easy fix. My MacBook is getting a little old ('08 model) but it still serves my purposes so it was worth the cost of a new battery. Couldn't find a better price anywhere, and the repair guides were clear and helpful. I only wish I had done this sooner!
My Problem
The airport card didn't work fine. After years of use the wireless connection was impossible and i could go in internet only with the ethernet cable. Also the battery, after years of use didn't keep the power, i could use the macbook only with the power cable connected.
My Fix
All fine! Very simple find the right component with my model.
I picked up the most recent compatible airport card and watching the manual was very easy to install it. All fine and now my macbook is as new!!!
My Advice
The only advice is to store the screws not all togheter because they are all similar and is not easy to place them into the right place if not stored separately step by step
Jon's Story Photo #215536
My Problem
My Macbook battery had been dead for a while. I finally broke down and purchased a new one. The swap was uber simple.
My Fix
Out with the old, in with the new!
My Advice
Order from ifixit... their customer service is by far the best.
My Problem
Battery was old, not holding charge anymore
My Fix
Easy, not really a repair, just changing batteries..
My Advice
Have a coin with you
My Problem
My Fix
My Advice
My Problem
The battery was bulging slightly, warping the bottom of the laptop. I found several references to this in Mac forums as a symptom of an aging battery. I noticed that it was difficult to get the MagSafe power adapter to recharge the battery sometimes: I had to keep reseating the adapter until the light started glowing. I thought replacing the battery might help with this as well.
My Fix
There's nothing to it. Shut down the Mac, turn the slot with a coin, pop out the old battery, slip in the new one, and charge it up overnight.
My Advice
Replacing the battery did not help with the charging issue. (I still think it is worth it to have a healthy battery that holds a charge longer.) I discovered that the MagSafe adapter port on the side of the MacBook had attracted a used staple that was hiding in one corner. Of course this made it harder to get the adapter to sit properly. Once I realized it was there, it was easy to remove. The adapter is still finicky. When I borrow a newer adapter the problem seems to go away.
