Click Image To Zoom
12.7 mm Optical Bay ATA Hard Drive Enclosure
$39.95 Was $59.95
You save $20.00!
Product code: IF107-077-1
Product Overview
You can now have two hard drives in your laptop or Mac Mini! By replacing your optical drive, you can install up to a 320 GB hard drive in this enclosure to increase your available storage space. This drive also is available via Target Disk Mode when connected to another Mac using Firewire.
Optical Bay is 12.7 mm tall. Accepts 2.5 inch ATA hard drives up to 9.5 mm in height.
Note: This enclosure does not work with SATA drives or drives taller than 9.5mm.
Compatibility
  • G4 Titanium Onyx PowerBooks with combo drives
  • G4 Titanium DVI PowerBooks with combo drives
  • All G4 Aluminum PowerBooks
  • All iBook G4s
  • All PowerPC Mac minis
Product Details
  $39.95
Condition:
New
Warranty:
6 month warranty
Add to Cart »
12 Available
Quantity:
Install Videos
Replacement Guides
iBook G4 12" 1.33 GHz
Difficulty: Difficult
iBook G4 12" 800 MHz-1.2 GHz
iBook G4 14" 1.42 GHz
Difficulty: Moderate
iBook G4 14" 933 MHz-1.33 GHz
PowerBook G4 Aluminum 12" 1-1.5 GHz
PowerBook G4 Aluminum 12" 867 MHz
PowerBook G4 Aluminum 15" 1-1.5 GHz
PowerBook G4 Aluminum 15" 1.67 GHz
PowerBook G4 Titanium DVI
PowerBook G4 Titanium Onyx
Compatibility
1.33 GHz
1 GHz
1.2 GHz
800 MHz
1.42 GHz
1 GHz (128 RAM)
1 GHZ (256 RAM)
1.2 GHz
1.33 GHz
933 MHz
Mac mini (PowerPC)
1.25 GHz
1.33 GHz
1.42 GHz
1.5 GHz
1 GHz
1.33 GHz
1.5 GHz
867 MHz
1 GHz
1.25 GHz
1.33 GHz
1.5 GHz (BT 1.1)
PowerBook G4 Aluminum 15" 1.5-1.67 GHz
1.5 GHz (BT 2.0)
1.67 GHz (Low-Res)
1.67 GHz (High-Res)
PowerBook G4 Aluminum 17" 1-1.67 GHz
1 GHz
1.33 GHz
1.5 GHz
1.67 GHz (Low-Res)
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res)
1.67 GHz (High-Res)
1 GHz
667 MHz
800 MHz
867 MHz
550 MHz
667 MHz
