Click Image To Zoom
1 TB 5400 RPM 2.5" Hard Drive
$99.95
Product code: IF107-106-1
Compatibility
  • All MacBooks and MacBook Pros (excluding MacBook Air and MacBook Pro Retina)
  • All Intel Mac minis
  • All Sony PS3 and PS3 Slim consoles
Product Details
  • Interface: SATA 3.0Gb/s
  • Speed: 5400 RPM
  • Dimensions: 2.5" (69.85mm) x .37" (9.5mm)
  • Capacity: 1 TB Unformatted
  • Cache: 8 MB
  $99.95 Toshiba
Condition:
New
Warranty:
3-year manufacturer warranty
Notes:
Model #: MQ01ABD100
Add to Cart »
9 Available
Quantity:
Replacement Guides
Mac Mini Mid 2010
Difficulty: Moderate
Mac Mini Mid 2011
Mac mini Model A1176
Mac mini Model A1283
MacBook Core 2 Duo
Difficulty: Easy
MacBook Core Duo
Difficulty: Easy
MacBook Pro 13" Unibody Mid 2009
MacBook Pro 13" Unibody Mid 2010
MacBook Pro 15" Unibody Mid 2009
MacBook Pro 15" Unibody Mid 2010
MacBook Pro 17" Unibody
MacBook Unibody Model A1278
Difficulty: Easy
MacBook Unibody Model A1342
PlayStation 3
PlayStation 3 Slim
Compatibility
Mac Mini Mid 2011
2 GHz (Quad i7, Mid 2011)
2.3 GHz (Dual i5, Mid 2011)
2.5 GHz (Dual i5, Mid 2011)
2.7 GHz (Dual i7, Mid 2011)
1.5 GHz (Core Solo, A1176)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo, A1176)
2 GHz (Core 2 Duo, A1283)
2.26 GHz (A1283)
2.53 GHz (A1283)
2.66 GHz (A1283)
Mac mini Model A1347
2.4 GHz (Core 2 Duo, Mid 2010)
2.66 GHz (Core 2 Duo, Mid 2010)
MacBook Core 2 Duo
1.83 GHz (Core 2 Duo)
2 GHz (C2D, Late 2006)
2 GHz (C2D, Mid 2007)
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz (Core 2 Duo)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
MacBook Pro 13" Unibody Early 2011
2.3 GHz (Early 2011)
2.7 GHz (Early 2011)
MacBook Pro 13" Unibody Late 2011
2.4 GHz (Late 2011)
2.8 GHz (Late 2011)
2.26 GHz (Mid 2009)
2.53 GHz (Mid 2009)
2.4 GHz (Mid 2010)
2.66 GHz (Mid 2010)
MacBook Pro 13" Unibody Mid 2012
2.5 GHz (Mid 2012)
2.9 GHz (Mid 2012)
MacBook Pro 15" Core 2 Duo Model A1211
2.33 GHz (Core 2 Duo)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 15" Core Duo Model A1150
1.83 GHz (Core Duo)
2 GHz (Core Duo)
2.16 GHz (Core Duo)
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
2.53 GHz (Mid 2009)
MacBook Pro 15" Unibody Early 2011
2 GHz (Early 2011)
2.2 GHz (Early 2011)
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz (Late 2008)
2.53 GHz (Late 2008)
2.66 GHz (Early 2009)
2.8 GHz (Late 2008)
2.93 GHz (Early 2009)
MacBook Pro 15" Unibody Late 2011
2.2 GHz (Late 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2.66 GHz (Mid 2009)
2.8 GHz (Mid 2009)
3.06 GHz (Mid 2009)
2.4 GHz (Mid 2010)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2010)
MacBook Pro 15" Unibody Mid 2012
2.3 GHz (Mid 2012)
2.6 GHz (Mid 2012)
2.7 GHz (Mid 2012)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2009)
2.8 GHz (Mid 2010)
3.06 GHz (Mid 2009)
MacBook Pro 17" Unibody Early 2011
MacBook Pro 17" Unibody Late 2011
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2 GHz (A1278)
2.4 GHz (A1278)
2.26 GHz (A1342)
2.4 GHz (A1342)
PlayStation 3
CECHA
CECHB
CECHC
CECHE
CECHG
CECHH
CECHJ
CECHK
CECHL
CECHM
CECHP
CECHQ
PlayStation 3 Slim
CECH-20xx
CECH-21xx
CECH-25xx
Stories
My Problem
This Mac Mini I bought through ebay last year, but the guy that put it on ebay - had not upgraded anything on it (except for upgrading the OS to OS X Snow Leopard)
My Fix
I installed a 1TB drive not once, not twice but three times - thinking that the computer was not recognizing it (dummy here ((me)) forgot to create a partition for the computer to write the information on first). Except for that little detail, the installation went beautifully - except for the bumps I kind of expected while putting it back together.
My Advice
Six words - "Plan it out step by step". Because no matter how smart you think you are, you're still only human - you can still forget something along the way or just miss something due to oversight.
My Problem
MacBook Pro would no longer startup. Did troubleshooting and determined that the hard drive was the problem. Ordered a new one.
My Fix
Using the fantastic iFixit guide, I EASILY replaced the hard drive, Installed OS X and was back up in no time.
My Advice
Just make sure to keep the parts that you remove in order. Makes it much easier to put back together.
My Problem
DVD quit...hard drive way too small!!!!
Friend was afraid to dig in...So I jumped in...
My Fix
Remove the screws...pull it apart...put it back together...wala!!!
All works like a champ!!!
My Advice
Go slow and don't over tighten anything...snug is cool.
My Problem
My Macbook Pro had a mere 500 GB HD, and was full. I couldn't find enough stuff I wanted to delete, so I couldn't even upgrade anything.
My Fix
The replacement of the HD with a 1 TB HD was perhaps the easiest "repair" I've ever done. I now have hopefully a while before this HD gets full.
My Advice
Before replacing the HD, I cloned my current HD with SuperDuper to an external HD, then booted my Macbook from the clone and copied the clone to my new HD. I then rebooted from the new HD and am off and away.
My Problem
2.4 GHz (Late 2011) MBP Unibody 13" - Looooong pauses during normal use....no hard crashes. After checking the logs and noting some i/o errors I figured it was time to replace the hard drive. Again.
My Fix
The fixit site directions on swapping the hard drive were excellent.
My Advice
Turns out that: long pauses, and then severe difficulty in getting OS installed on replacement drive (both via time machine backup and Recovery tool), and hours of web researching, and a trip to the Genius Bar equals damaged hard drive cable.
(Not a bad drive, or corrupt files)
Also the re-install OS directions on the Fixit site did not include adding a recovery partition and installing a fresh OS via recovery tool. That would have been helpful. My first run used a cloned version of old drive. When I ran into problems I guessed that the drive errors had created problems on the new drive. Not so much.
My Problem
Not enough space
My Fix
It was very interesting but at the same time easy with so detail inctruction from site iFixit. Thanks!
My Advice
Thanks iFixit. YOu make our life easier ;)
cgreninger's Story Photo #216043
cgreninger's Story Photo #216044
cgreninger's Story Photo #216045
My Problem
500gb x2 was not enough for the server.
My Fix
All went pretty well although I didn't know I needed a special tool to back out the logic board.
My Advice
I used two wooden skewers as my Logic Board Removal Tool. I used my pocket knife to narrow down the ends. Wood was less abrasive than using a small screwdriver. Also, the guide only covers the removal of one hard drive (the bottom bay). To remove the second drive, you'll have to go ahead and remove the board entirely to gain access.
My Problem
i want more space on my macbook, so i bought a 1 TB hd.
My Fix
the repair goes well, it was very simple and quick, no hard passages!
My Advice
Don't worry, it's very simple!
My Problem
Needed more disk space.
My Fix
Between your excellent toolkit
and your project mat
and, above all, your great instructions,
it went without a hitch!
My Advice
I cannot think of any way to improve this particular project.
Everything was exactly as shown. NO surprises!
My Problem
Running out of disk space...didn't want to buy a new machine...
I have a MacBook from late 2008 when Apple made the aluminum unibody and didn't call it a MacBook Pro. I love my Mac and did not want to spend more money on a new Mac until this machine no longer supports OS updates. So I wanted to up my operating speed by installing a 120gig Solid State Drive as my primary and to install a 1terabyte SATA drive in place of my optical drive for all my music, data, documents, etc.
My Fix
The repair was easy...because I did my homework studying everything on ifixit.com. I determined my needs and what would work on my particular machine and ordered it from iFixit.com. It all came quickly and in good working order. I followed the step-by-step instructions and used SuperDuper to transfer all my data from my old bootable drive. The next morning I awoke to a fresh solid state bootable drive. I installed the new drive and BAM! My computer is moving at BLAZING speed! And I have a whole terabyte to store al sorts of stuff. Oh, I also bought a portable Multi-Drive so I can still install DVD's and Cd's.
My Advice
Follow ifixit directions to the letter. They really did a great job and for the price of one-half of a new low-end macine I got my old machine crankin' and doing just fine. I shouldn't need another machine for several years now.
Watch out for stripping screws. Those tiny little buggers will strip if you are not careful. Set the screw driver in the screw and press firmly, then carefully turn the driver.
Related Questions
