PowerBook G3 or G4 24x Combo Drive (New)
Disabled
Product code: IF106-058
Product Overview
Slot loading drive. Currently does not support Apple disc burning in OS 9.x. Will burn using Toast in OS 9.x. Apple disc burning is supported in OS 10.2.x, 10.3.x, and 10.4.x.
Requirements for G3 Pismo:
This item must be installed in your existing DVD module housing. The module housing must be intact, but you can replace a non-working DVD drive. Installation is very simple and requires removing only four screws. The faceplate of this drive is not identical to the original DVD drive. This does not impact the operation of the drive.
Requirements for G4 Titanium or Aluminum:
Requires working ribbon cable and bracket from your current combo or super drive for installation. If you currently have a DVD drive you need to purchase a different drive which includes a special mounting bracket.
Compatibility
Identify your Mac
  • G3 Pismo PowerBooks
  • G4 Titanium Onyx PowerBooks with combo drives
  • G4 Titanium DVI PowerBooks with combo drives
  • G4 Aluminum PowerBooks
Installation Guides
PowerBook G3 Pismo
Difficulty: Easy
PowerBook G4 Aluminum 12" 1-1.5 GHz
Difficulty: Difficult
PowerBook G4 Aluminum 12" 867 MHz
PowerBook G4 Aluminum 15" 1-1.5 GHz
PowerBook G4 Aluminum 15" 1.67 GHz
Difficulty: Moderate
PowerBook G4 Titanium DVI
PowerBook G4 Titanium Onyx
Compatibility
PowerBook G3 Pismo
400 MHz
500 MHz
1 GHz
1.33 GHz
1.5 GHz
867 MHz
1 GHz
1.25 GHz
1.33 GHz
1.5 GHz (BT 1.1)
PowerBook G4 Aluminum 15" 1.5-1.67 GHz
1.5 GHz (BT 2.0)
1.67 GHz (Low-Res)
1.67 GHz (High-Res)
PowerBook G4 Aluminum 17" 1-1.67 GHz
1 GHz
1.33 GHz
1.5 GHz
1.67 GHz (Low-Res)
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res)
1.67 GHz (High-Res)
1 GHz
667 MHz
800 MHz
867 MHz
667 MHz
Related Products
Tools used in install guides
