My screen is blinking
I have to push and pull the lcd until find a position to image appear.
View:
Passed VotesAnyone with over 20 reputation can flag problematic comments and posts.
Show details
Posted:
originalmachead @originalmachead
Rep: 116.3k
Posted:
Sounds like you have damaged a cable... either the data display cable or the inverter cable.
That is not a hard DIY fix. Aquire the proper tools (any job is easier when you use the correct tool). Use the guide to remove the top case... inspect the cables for nicks/cuts, carefully moving the cable with a plastic/wooden tweezer or toothpick (to avoid shorting) can tell you which one is the problem... order a replacement an swap it out.
If this Answer is helpful please remember to return and mark it Accepted.
Oops! I'd like to change my mind.
Expand / Collapse
Pass
Up
Fail
Down
Open Help
Page 1 of 1
