Click Image To Zoom
Customers also bought
Share this Product
Installation Guides
MacBook Pro 15" Unibody Mid 2009
Difficulty: Moderate
MacBook Pro 15" Unibody Mid 2010
Difficulty: Easy
Compatibility
| MacBook Pro 15" Unibody 2.53 GHz Mid 2009 |
| MacBook Pro 15" Unibody Mid 2009 |
| MacBook Pro 15" Unibody Mid 2010 |
Stories
My Problem
The unibody case had been bent from a fall. The battery was not fully recharging.
My Fix
Fine, but I didn't do it. I hired someone to do the repair.
My Advice
I tried to replace the top part of Macbook Pro but had to hire someone to do it after I failed.
My Problem
Battery on my 3 yr old MacBook Pro no longer could take a charge reliably. Didn't want to take my laptop in and leave it at the store, so decided to replace it myself after reading ifixit.
My Fix
Easy repair. Took 15 minutes and five of those minutes was dealing with my cat who kept jumping on the table.
My Advice
Make sure to have the right tools. Now I wish I'd also upgraded my hard drive while I had the laptop open. Oh well, will do another time. Great site.
My Problem
I had bad battery time
My Fix
Very easy to change the battery
My Advice
No just follow the guide
My Problem
After 2 years, osx indicated "service battery" and capacity was down to approx. 30%
My Fix
Replacement is pretty easy, about 10 screws, nothing more
My Advice
No, it is pretty simple, nothing can go wrong.
My Problem
My wifes battery on her MBP stopped holding a charge. Since I've opened laptops before I knew it couldn't be too hard to replace. So I called Apple to order a battery, and they tell me I have to take it to an Apple store to have it changed out. I said I know how to do it, can I buy a battery. They said you can't open your laptop. I said I already did, I know how to change the battery. They said, with alarm, you can't open your laptop!!!! I said what what do you mean I can't open it? It's my laptop!
Anyways, I gave up on that and headed over to iFixit. It was actually easier to navigate to the part I needed than on the apple website.
My Fix
First of all, removing the back is a cinch, just make sure you don't loose the screws. The battery had 5 point star screws that needed a special screw driver. I didn't want to spend the extra $12 so I took a small flat screwdriver and filed it down so it would fit in two of the five points. Then I applied steady pressure until the screws gave. There was a little stripping on two of them before I got the screwdriver filed down right, but I wasn't worried because once I got the screws loose I knew I would be able to do it again if needed. The battery terminal connection was a little awkward to reconnect since the cables run under the battery and there is very little wiggle room. That part took some hand/eye coordination.
My Advice
The change out was easy, but like I said before, I have opened up several other laptops and I knew what I was looking for. I am disappointed that apple is not making the battery easy to replace, since it's probably the only thing that will need regular maintenance. Thank God for iFixit tho.
Thanks iFixit!
My Problem
The battery was not holding charge and needed to be changed.
My Fix
Changing it went fine. I was happy to find a company from which I could obtain a battery for this late model Mac. I was even happier when I read the story of your company startup and that you are in California. The battery was delivered less than 24 hours after I ordered it!
My Advice
There ought to be a better way to determine if the MacBook Pro is mid-2009 or mid-2010 because of the difference in the screws that hold the battery in. I modified one of the flat electronics screwdrivers I have and used it to remove and reinstall those three screws.
My Problem
Battery life diminishing.
My Fix
Went very well. I followed the instructions and got it done under half an hour. I'm happy.
My Advice
None actually. Just have to be careful not to turn the screws too hard. Might damage the delicate screw threads.
My Problem
My MBP battery died more than a year. It could only last for around 2 hours or less.
My Fix
Everything go smoothly as the guide described. I brought a set of screwdriver bit from local store and surprisingly, it does include star shaped screwdriver for macbook pro battery!. It costs less than $100 HKD which is around USD 12.
During the removal of old battery, I found that all three mount point of it is broken, might be caused by few times of falling down.
My Advice
The initial Full Charge Capacity seems varies and keep decreasing to 67xxmah. But it raise up to 71xxmah after few days of use. So don't panic.
