Click Image To Zoom
Installation Guide
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
Difficulty: Very difficult
Required Tools Add All Tools to Cart »
Spudger
$2.95 ·Add to Cart »
T6 Torx Screwdriver
$4.95 ·Add to Cart »
Compatibility
| MacBook Pro 15" Core 2 Duo Models A1226 and A1260 |
Stories
My Problem
I tripped in the terminal at Detroit Metro Airport, fell and landed on my Macbook, cracking the LCD screen. Apple wanted $1200 to fix it!?
My Fix
The repair went flawlessly. The instructions are phenominally detailed. The tools I ordered for assembly made the process easier than I expected.
My Advice
The one key is to be VERY organized with the parts you take off. Have a container for each set of screws you take off and keep the containers lined up in the order you took them off.
My Problem
I dropped my computer and cracked the LCD screen.
My Fix
using the guide on iFixit, my friend and I spent the afternoon in the basement of our favorite coffee shop with an allan wrench, tiny screw driver set and a paint scrapper replacing the screen.
Works great!
My Advice
The most tricky/difficul
Reconnecting the isight wire was also tough (it kept falling back out.)
Also connect your wires and test everything first before putting ALL of your screws back in, just in case you missed a wire.
My Problem
The LCD screen was only useful on the right half. The left half was damaged. I went to the Apple store and they had no stock to repair and would replace with a similar computer for $1200. After two other web stores were out of stock with little hope of getting new stock in, I bought a replacement LCD screen for my powerbook pro from iFixit.
My Fix
The replacement took 2-3 hours. It went slowly because of the delicate nature of many parts. The reassembly was much faster than disassembly. The directions on the iFixit web site were clear but had to be read carefully. When turned back on the familiar apple startup screen came up immediately proving the screen was functional.
My Advice
Separate screws as you go. I used 5 containers that held the screws in the order of removal. Do the work in a location were the very small screws can be easily found if dropped. Read directions carefully and go slowly.
Related Questions
| 3 Answers 0 Score | Can I only replace the lcd | |
| 1 Answer 1 Score | How do I replace the LCD? |
| 1 Answer 0 Score | Screen not working. LCD or logic board problem? | |
| 3 Answers 0 Score | screen broken- how to get a cheap replacement? |
| 1 Answer 0 Score | What brand is the LCD Panel? | |
