Click Image To Zoom
MacBook Pro 15" (Models A1150/A1211) LCD Panel
$229.95
Product code: IF185-099
Product Overview
CCFL backlit LCD panel. Glossy and matte finish LCDs are interchangeable, you can install either type in your MacBook Pro 15", regardless of the original LCD panel type
Please use our ID your Mac page to ensure this is the correct LCD panel for your computer. This LCD is only compatible with MacBook Pro 15" laptops that are model A1150 or A1211 (printed on the bottom of the laptop).
Compatibility
Identify your Mac
  • 1.83, 2 or 2.16 GHz (Model A1150) 15" MacBook Pros
  • 2.16 or 2.33 GHz (Model A1211) 15" MacBook Pros
Product Details
  • Size: 15.4"
  • Resolution: 1440x900
$229.95 Glossy / New
Condition:
New
Warranty:
6 month warranty
Notes:
Glossy finish screen. LCD is new and in excellent condition.
$229.95 Matte / New
Condition:
New
Warranty:
6 month warranty
Notes:
Matte finish screen. LCD is new and in excellent condition.
Installation Guides
MacBook Pro 15" Core 2 Duo Model A1211
Difficulty: Very difficult
MacBook Pro 15" Core Duo Model A1150
Compatibility
2.16 GHz (Core 2 Duo)
2.33 GHz (Core 2 Duo)
1.83 GHz (Core Duo)
2 GHz (Core Duo)
2.16 GHz (Core Duo)
Stories
My Problem
Left laptop in cold car and screen went bad. Tried to just replace inverter thing, but that wasn't it. Had to do the big LCD replacement.
My Fix
SMOOOOOOTH! ifixit is great! Got the part(s), the tools and clear, well-written, well-depicted directions and fixed my Macbook. It was weirdly fun and gratifying.
My Advice
use ifixitcom to fix your tech-y stuff
My Problem
My daughter's laptop LCD display got broke because my other daughter decided to through the remote and hit and broke the screen.
My Fix
The repair went without a hitch. I took it nice and slow. The only problem I had was with the spudger and using it to separate the pieces.
My Advice
Get the spudger. It is good for keeping things separated and putting the connectors back on. Get a set of small screwdrivers and use one of the larger screwdrivers to do the separating of the screen and the LCD display.
My Problem
I drenched my old MBP with water, when I dropped a water bottle on it. I was getting it ready to ship to a buyer. After drying it out for three days, everything was fine except for the display.. It no longer functioned properly. I checked the inverter, it was fine, so determined it to be the display itself.
My Fix
The repair was straightforward because I went through your instructions several times before taking the display apart. I've made upgrades to the MBP several times (disk drive upgrade, replaced the cooling fans, airport upgrade, etc) so getting into it is old-hat. I had no problems with the display, was able to get the bezel off by doing exactly as your instructions said. I put everything back together and powered up - - - Beautiful! Better than I remember it looking new.
My Advice
1. Make sure you have the right tools
2. Review what you are going to do using the instructions / guides
3. Take your time and move slowly. You don't want to loose any screws.
4. Make note of how you took things apart and move backward through the instructions putting things back together again.
5. Make sure that you keep the screws sorted by instruction step. You will get to know which are which, but don't want to try to cross thread a screw that is the wrong one (messing up the threads - there is an old story there for another time).
Related Questions
