Click Image To Zoom
Installation Guide
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
Difficulty: Difficult
Required Tools Add All Tools to Cart »
Spudger
$2.95 ·Add to Cart »
T6 Torx Screwdriver
$4.95 ·Add to Cart »
4mm Nut Driver
$6.95 ·Add to Cart »
Compatibility
| MacBook Pro 15" Core 2 Duo Models A1226 and A1260 |
Stories
My Problem
MacBook Pro 15" 1260 - logic board defective and audio jack broken off in the left I/0 audio port.
My Fix
Replaced both fans - left I/0 board and logic board using ifixit guides. Guides were superb, repair done in no time and machine working perfectly. I replaced a 2.5 board with a 2.6 and have a slightly faster machine too!
My Advice
No too difficult - just be methodical and follow the instructions in the guides.
My Problem
I sent my machine to Apple for a free out of warranty logic board replacement and while in their care, they broke the left IO board! Because it was sent in initially for "display issues" (lines through the screen), they considered this a pre-existing condition and it was going to cost me over $300 to fix! Someone call Obama.
My Fix
The repair went smoothly. The board from iFixit came quickly and the instructions were very helpful and clear. After about 20 minutes (I've done this before), my machine was good as new! Well, good as it was before anyway.
My Advice
If you have a display that won't light up on a Macbook Pro from 2008, don't immediately assume the LED driver board is dead. That repair takes a bit longer and disassembling the display is dicey even with good instructions. If at all possible, swap the display into another Macbook Pro to see if it really went bad. It might be just be fine. If it is, then the left IO board is the real culprit.
Oh, and when reattaching the screws on the express card stage, there are 4 screws of 3 different sizes. Be absolutely certain each is in its right place.
Related Questions
| 1 Answer 0 Score | Replacing power jack on MacBook Pro 15 A1260 | |
| 1 Answer 0 Score | MacBook Pro not starting up, no response after manual power... | |
| 2 Answers 0 Score | My MacBook Pro 2.4 Ghz don't have sound, Airpor, Usb, screen black |
| 2 Answers 0 Score | Battery won't charge, Magsafe connector stays green |
