Click Image To Zoom
MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
$29.95
Product code: IF186-056-1
Product Overview
Includes LCD mounts and airport antenna cables. This part works with model A1181 MacBooks with 2 antenna connectors. If your MacBook has 3 antenna connectors you need the Core 2 Duo hinge mounts.
Compatibility
Identify your Mac
  • 1.83 or 2 GHz Core Duo MacBooks
  • 2.0 (Santa Rosa) or 2.2 GHz Core 2 Duo MacBooks
  • 2.1 or 2.4 GHz Core 2 Duo MacBooks
  • 2.0 GHz (Early 2009) Core 2 Duo MacBooks
  • 2.13 GHz (Mid 2009) Core 2 Duo MacBooks
Product Details
  $29.95
Condition:
Used, fully tested
Warranty:
6 month warranty
Add to Cart »
28 Available
Quantity:
Compatibility
MacBook Core 2 Duo
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
Stories
My Problem
My airport would only work if the computer did not move after startup. If moved the airport would turn off and could not be turned back on without restarting. After researching the problem I deduced that it was probable that the antenna wires had been pinched/worn from the screen opening and closing for three years.
My Fix
The repair took me quite a while, about 2-3 hours. I followed the installation guide to the letter and when completed my wireless works like it supposed to. I even shook the computer just to test it. The hardest part was step 20 putting the screw back into the cd drive. I used the spudger and a screwdriver with some patience to get it back in. Also, don't break/lose the small grey clips that hold the display bezel in place, as you will have no replacements.
My Advice
The screws are hard to keep track of after removal. If you can, use some sort of divided tray for all the different sizes. Or use a metric tape measurer to figure it out like me.
