Click Image To Zoom
Installation Guide
MacBook Air Models A1237 and A1304
Difficulty: Moderate
Required Tools Add All Tools to Cart »
Compatibility
| MacBook Air Models A1237 and A1304 |
Stories
My Problem
The system was still like new so it would be a shame to recycle it.
I installed a new SSD 128GB and the new battery and it runs like a champ. I bench marked it net to a MacBook Pro and it was fatser in all areas.
My Fix
The repair took about 20 minutes and it was very simple. The only reason it took 20 minutes was because I had never taken one of these apart and I wanted to look around.
My Advice
Make a screw guide as you are working or pull one down from the web. Many different sized screws that can make reassembly a bit tricky.
My Problem
My MacBook Air completely quit. No power at all. No video. No Fan. Nothing. It seemed clear that it must be the battery or the MagSafe card.
My Fix
The repair never really happened because it was discovered that the actual problem was on the logic board. I am delighted that iFixit has a return policy that allows me to return the parts for a refund (there is an understandable restocking fee). I am VERY happy with this!!
My Advice
Working with iFixit has been nothing but pleasant. Great detail on how to debug and fix. A great supply of parts, even for older models. And as I say above, a generous return policy for us idiots who order the wrong parts.
My Problem
The old battery in my original 2008 macbook air was swollen so I needed to get it replaced.
My Fix
The repair went smoothly, thanks to iFixit's guides!
My Advice
Just go slow, take your time when taking apart the mac air and watch out for swollen batteries.
My Problem
my battery was out of date
My Fix
very well no problem
My Advice
use the ifixit manual precisely
My Problem
Original battery lost its charge
My Fix
Repair was straightforward
My Advice
Give it a go!
My Problem
Battery had dropped to providing approximately three minutes charge.
My Fix
Remarkably well - though one screw just wouldn't come out, and I had to gently break the battery. Luckily the screw then came out and the new battery went in fine.
My Advice
Good lighting, and be methodical about keeping track of which screw goes where (I laid them out on two pieces of paper). Remember to connect the new battery up before replacing the outer case... :-)
