Click Image To Zoom
MacBook 802.11n Airport Extreme Card
$89.95
Product code: IF185-038-1
Product Overview
The internet's not only responsible for the rapid dissemination of information. It's also responsible for creating new kinds of jobs, from internet service providers to internet plumbing companies. Access that series of tubes today with our MacBook 802.11n Airport Extreme Card.
Upgrade your Core Duo MacBook or MacBook Pro to 802.11n to make your wireless up to five times faster. Replaces internal 802.11g Airport card with 802.11n, but retains backwards compatibility with 802.11g. An 802.11n base station is required to obtain improved wireless performance.
Requires Leopard (10.5) or later. If you have Tiger (10.4) you will need the disc that came with your airport base station to enable the card.
Compatibility
Identify your Mac
  • 1.83 or 2 GHz Core Duo MacBooks
  • 1.83, 2 or 2.16 GHz 15" (Model A1150) MacBook Pros
  • 2.16 GHz (Model A1151) 17" MacBook Pros
Product Details
  • Model #: BCM94321MC
  • Airport: 802.11n
  $89.95
Condition:
Used, fully tested
Warranty:
6 month warranty
Add to Cart »
37 Available
Quantity:
Installation Guides
MacBook Core Duo
Difficulty: Moderate
Compatibility
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
MacBook Pro 15" Core Duo Model A1150
1.83 GHz (Core Duo)
2 GHz (Core Duo)
2.16 GHz (Core Duo)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
Stories
My Problem
To upgrade my 2006 vintage macbook pro intel duo to 802.11n wireless.
My Fix
Went very well. The photos on your website were fantastic and easy to follow. When finished, the wireless was finally up to speed with my current Airport configuration (802.11n). I would definitely recommend your site to others. Thanks.
My Advice
Follow the pictures on the website and make sure you have the right tools to get the Macbook open to access the Airport card.
My Problem
MacBook with original wireless card would only connect within a few feet of an access point. I used the fixit guide to open it and make sure the antenna was correctly connected, but that did not solve the problem. So I decided to replace the wifi card with the n model.
My Fix
When the part arrived, I used the fixit guide again to install the replacement. It took about an hour and worked perfectly.
My Advice
I used an ice cube tray as a screw sorter. There is another MacBook in the family with a bad optical drive. I might repair it if I find a low cost replacement drive.
My Problem
My 6 year old MacBook Pro needed a new wireless card; seeing that I couldn't even connect to the internet in my own home. It was definitely time to upgrade the card.
My Fix
The instructions were straightforward. Repair was quite simple. I was scared at first but Mac is very forgiving!
My Advice
I'm not sure if this has happened to others but the release button to open the laptop was a tad jammed. The Genius Bar fixed that problem. It couldve been the way I was handling the repair.
My Problem
After eight or so years I ran out of hard drive space (who thought 70GB was too small way back then?). And dealing with the ethernet cable running through the floor from the basement was getting old - what's the point of a laptop if you can't use it on your lap top?
My Fix
The repair was pretty boring. Printed out the instructions, taped the screws to the appropriate photos, followed the instructions to the end and then moved to the other side of the table and followed them backwards (not really). Hit the power button and everything booted up the same - only faster and from further away (no ethernet cable). I also now have a nice, "new", 70GB external hard drive to back up another old computer.
The only concern now is what the heck am I going to do with 500GB? (I know, I know...)
No problems, no issues, no story. Sorry...
My Advice
Don't worry, be happy - upgrade now.
(One piece of info unrelated to ifixit: the new OS Lion won't run on the older Intel Core Duo - you need at least the Core 2 Duo.)
My Problem
My airport has been weak for years. But I hesitated to spend the money at the GeniusBar.
My Fix
Perfect. Easy. I followed the photos and moved carefully and it went perfectly without a hitch.
My Advice
I used a plastic multi-compartment container for the different types of screws. The Spudger was essential. I used a magnifying glass to see the airport card antennae connectors carefully to be sure they were re-attached firmly after installing the new card.
My Problem
The old Airport started having connectivity issues, and would eventually stop detecting the wireless router (the range was somewhere between 5mins to 45mins max, and then would drop) - leaving me totally deprived of internet access!
My Fix
The process was pretty straight forward. Following the pictures was great. Conversely, I can see how someone might mix the screws...so just remember to keep them segregated. What I did was basically put them on top of a sheet of paper , and drew a circle around them, and pointed them to a step # (which of course I also wrote on the sheet). That prevented me from getting lost.
My Advice
don't be afraid to use the force (physical) on those prongs and connections! oh, and keep your screws separated.
Related Questions
