iMac Intel 20" EMC 2105 and 2118 Parts
This rendition is Apple's first desktop machine to feature Intel processing. The Core Duo (2 GHz) and Core 2 Duo (2.16 and 2.33 GHz) processors greatly increased speed and efficiency.
Need more memory? Two PC2-5300 1 GB RAM chips will max out your memory at 2 GB. A 1 TB 7200 RPM SATA hard drive will top you off.
Select your speed above or browse all compatible parts to find what you need to fix your machine!
Results
Showing products 1 - 10 of 15
| | 3 TB SATA Desktop Hard DriveSATA interface for iMac G5s and Intel iMacs / 3.5" wide x 1" tall / 3 TB Unformatted | $179.95–$199.95 |
| | 2 TB SATA Desktop Hard DriveSATA interface for iMac G5s and Intel iMacs / 3.5" wide x 1" tall / 2 TB Unformatted | $149.95–$159.95 |
| | iMac G5/Intel Power SupplyPower Supply for iMac G5 and iMac Intel 17" & 20" | $139.95 |
| | 1 TB SATA Desktop Hard DriveSATA interface for iMac G5s and Intel iMacs / 3.5" wide x 1" tall / 1 TB Unformatted | $129.95 |
| | 12.7 mm PATA 8x SuperDriveBurn CDs and DVDs with your computer. | $89.95–$99.95 |
| | 12.7 mm PATA 8x SuperDrive (UJ-846-C)Burn CDs and DVDs with your computer. | $89.95 |
| | 12.7 mm PATA 24x Combo DriveBurn CDs and play DVDs. | $69.95 |
| | 12.7 mm PATA 4x SuperDrive (24X CDR)Burn CDs and DVDs. | $69.95 |
| | PC2-5300 1 GB RAM ChipRAM Upgrade / 1 GB / PC2-5300 / Low Profile / 200 pin, 667 MHz | $29.95 |
| | Universal Drive AdapterTransform any bare drive (SATA or IDE) into an external storage solution | $29.95 |
