iMac 24" 2.33 GHz Parts
The introduction of the Intel Core 2 Duo processors added more power under the hood of this version. The addition of a Firewire 800 port added connectivity.
Need more memory? A PC2-5300 2 GB RAM chip and a PC2-5300 1 GB RAM chip will max out your memory at 3 GB. A 2 TB SATA hard drive will top off your storage capacity.
Select your category below or browse all compatible parts to find what you need to fix your machine!
Results
4 TB 7200 RPM 3.5" Hard Drive
SATA 6.0 Gb/s interface for iMac G5s and Intel iMacs / 7200 RPM / 3.5" wide x 1" tall / 4 TB Unformatted
See full description
$209.95
3 TB 7200 RPM 3.5" Hard Drive
SATA 6.0 Gb/s interface for iMac G5s and Intel iMacs / 7200 RPM / 3.5" wide x 1" tall / 3 TB Unformatted
$179.95
12.7 mm PATA 8x Pioneer SuperDrive
Burn CDs and DVDs with your computer.
$89.95
iMac Intel 24" 2.16/2.33 GHz Power Supply
Power Supply for iMac Intel 24"
$139.95
2 TB 7200 RPM 3.5" Hard Drive
SATA 6.0Gb/s interface for iMac G5s and Intel iMacs / 7200 RPM / 3.5" wide x 1" tall / 2 TB Unformatted
$129.95
1 TB 7200 RPM 3.5" Hard Drive
SATA 6.0 Gb/s interface for iMac G5s and Intel iMacs / 7200 RPM /3.5" wide x 1" tall / 1 TB Unformatted
$109.95
PC2-5300 2 GB RAM Chip
RAM Upgrade / 2 GB / PC2-5300 / Low Profile / 200 pin, 667 MHz
$44.95
12.7 mm PATA Optical Bay SATA Hard Drive Enclosure
12.7 mm Internal ATA Optical Bay for SATA Hard Drives
Retail price: $59.95 — You save $20.00!
$39.95
PC2-5300 1 GB RAM Chip
RAM Upgrade / 1 GB / PC2-5300 / Low Profile / 200 pin, 667 MHz
$24.95–$29.95
Universal Drive Adapter
Transform any bare drive (SATA or IDE) into an external storage solution
$29.95
