iMac 20" 2.66 GHz (EMC No. 2266) Parts
This iMac features faster graphics processing and adds a fourth USB port.
Need more memory? Two PC3-8500 2 GB RAM chips will get you moving faster! A 2 TB SATA hard drive will top off your storage capacity.
Select your category below or browse all compatible parts to find what you need to fix your machine!
Results
3 TB SATA Desktop Hard Drive
SATA interface for iMac G5s and Intel iMacs / 3.5" wide x 1" tall / 3 TB Unformatted
See full description
$299.95
2 TB SATA Desktop Hard Drive
SATA interface for iMac G5s and Intel iMacs / 3.5" wide x 1" tall / 2 TB Unformatted
$249.95
1 TB SATA Desktop Hard Drive
SATA interface for iMac G5s and Intel iMacs / 3.5" wide x 1" tall / 1 TB Unformatted
$199.95
iMac Intel 20" Glass Panel (EMC No. 2266)
Replaces cracked or damaged glass on specified Intel iMacs.
$159.95
iMac Intel 20" 2.66 (EMC No. 2266) GHz Power Supply
Power Supply for iMac Intel 20"
$139.95
PC3-8500 4 GB RAM Chip
RAM Upgrade / 4 GB / PC3-8500 / Low Profile / 204 pin, 1066 MHz
$99.95
PC3-8500 2 GB RAM Chip
RAM Upgrade / 2 GB / PC3-8500 / Low Profile / 204 pin, 1066 MHz
$49.95
Universal Drive Adapter
Transform any bare drive (SATA or IDE) into an external storage solution
$29.95
SATA Wondercable USB Adapter
This USB adapter will allow you to plug in the most common SATA optical drives and hard drives.
$29.95
Apple USB Ethernet Adapter
Allows you to connect to the internet with an Ethernet cable via USB. Model A1277.
$24.95
