Titanium DVI 1 GHz Parts
The PowerBook Titanium DVI 1 GHz has the benefit of possessing two RAM slots in which you can put two 512 MB RAM chips for a total of 1 GB of memory. If you have an DVI that came with a Combo Drive and you are tired of waiting on slow burn times, then speed up the process with a 8x Super Drive.
Need help diagnosing the trouble? Check out our free troubleshooting guide!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 55
| | G4 Titanium DVI Display Assembly1280x854 LCD / 15.2" | $399.95 |
| | G4 Titanium DVI 1000 MHz Logic BoardMotherboard / 1000 MHz / Ports: Audio In, Audio Out , RJ11 Modem, 2 USB 1.1, 400Mbps Firewire, 1000BT Ethernet, S-Video Out, DVI-Video Out | $499.95 |
| | G4 Titanium DVI 867 MHz Logic BoardMotherboard / 867 MHz / Ports: Audio In, Audio Out, RJ11 Modem, 2 USB 1.1, 400Mbps Firewire, 1000BT Ethernet, S-Video Out, DVI-Video Out | $399.95 |
| | G4 Titanium DVI 800 MHz Logic BoardMotherboard / 800 MHz / Ports: Audio In, Audio Out, RJ11 Modem, 2 USB 1.1, 400Mbps Firewire, 1000BT Ethernet, S-Video Out, DVI-Video Out | $299.95 |
| | G4 Titanium DVI LCD PanelLCD without the display bezels, hinges, or cables / 1280x854 / 15.2" | $149.95 |
| | G4 Titanium DVI 667 MHz Logic Board (DVI)Motherboard / 667 MHz / Ports: Audio Out, AC Power, RJ11 Modem, 2 USB 1.1, 400Mbps Firewire, 1000BT Ethernet, S-Video Out, VGA-Video Out | $249.95 |
| | G4 Titanium DVI 1x SuperDriveDVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 1x DVD-R write, 1x DVD-RW write, 16x CD-R write, 8x CD-RW write | $199.95 |
| | G4 Titanium DVI Upper CaseUpper case includes trackpad, heat sink, battery contacts, Airport connector, and speakers | $199.95 |
| | G4 Titanium DVI Upper CaseUpper case includes trackpad assembly, heat sink, battery contacts, and speakers | $99.95–$149.95 |
| | 12.7 mm PATA 8x SuperDriveBurn CDs and DVDs with your computer. | $89.95–$99.95 |
