PowerBook G4 Aluminum 17" 1-1.67 GHz Parts
The Aluminum 17" has the benefit of possessing two RAM slots that can be filled with two 1 GB RAM chips. A 320 GB ATA hard drive will keep your laptop running like a champ with tons of hard drive space. You can even upgrade the optical drive to a 8x SuperDrive to ensure fast CD and DVD burning.
Use our free troubleshooting guide to help diagnose any problems with your machine.
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
G4 Aluminum 17" (LR) Display Assembly
1440x900 LCD / 17"
See full description
$499.95–$699.95
G4 Aluminum 17" 1/1.33/1.5/1.67 GHz (LR) LCD Panel
LCD without the display bezels, hinges, or cables / 1440x900 / 17"
$399.95
G4 Aluminum 17" 8x SuperDrive (UJ-835)
DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 4x DVD-RW write, 24x CD-R write, 16x CD-RW write
$199.95
G4 Aluminum 17" 4x SuperDrive
DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 4x DVD-R write, 2x DVD-RW write, 24x CD-R write, 16x CD-RW write
$179.95
320 GB 5400 RPM Western Digital ATA Hard Drive (New)
ATA interface for PowerPC Macs / Western Digital / 2.5" wide x 9.5mm tall / 320 GB Unformatted / 5400 RPM
$119.95
250 GB 5400 RPM Western Digital ATA Hard Drive (New)
ATA interface for PowerPC Macs / Western Digital / 2.5" wide x 9.5mm tall / 250 GB Unformatted / 5400 RPM
$109.95
G4 Aluminum 17" Display Data Cable
A damaged display data cable can cause video defects
$99.95
G4 Aluminum 17" Clutch Hinges
Clutch cover and hinges for G4 Aluminum 17" model
$99.95
G4 Aluminum 17" Display Inverter
A bad inverter board can cause a dead backlight
$99.95
G4 Aluminum 17" Battery
Upgrade your aging battery
$99.95
Main image
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
Ask a Question
Your cart is empty.
