Aluminum 15" 1.5 GHz Bluetooth 2.0 Parts
The Aluminum 15" 1.5 GHz (BT 2.0) has the benefit of possessing two RAM slots that can be filled with two 1 GB RAM chips. A 320 GB ATA hard drive will keep your laptop running like a champ with tons of hard drive space. You can even upgrade the optical drive to a 8x SuperDrive to ensure fast CD and DVD burning. If your PowerBook has wireless trouble, throw in a replacement Airport Extreme card and you will be ready for all the wireless net surfing you want to do while laying in bed on a lazy Saturday morning.
Use our free Aluminum 15" troubleshooting guide to help diagnose any problems with your machine.
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 76
| | G4 Aluminum 15" 1.67 GHz (128 VRAM, LR) Logic Board1.67 GHz Motherboard / Ports: 1000BaseT Ethernet, Firewire 400, Firewire 800, DVI Video Out, S-Video Out | $549.95 |
| | G4 Aluminum 15" 1.67 GHz Logic Board (64 VRAM, LR)1.67 GHz Motherboard / Ports: 1000BaseT Ethernet, Firewire 400, Firewire 800, DVI Video Out, S-Video Out | $499.95 |
| | G4 Aluminum 15" 1.5 GHz (BT 2.0) Logic Board1.5 GHz Motherboard / Ports: 1000BaseT Ethernet, Firewire 400, Firewire 800, DVI Video Out, S-Video Out | $449.95 |
| | G4 Aluminum 15" 1.5/1.67 GHz Display Assembly1280x854 LCD / 15.2" | $299.95–$399.95 |
| | G4 Aluminum 15" 1.5/1.67 GHz Lower CaseReplace a scratched-up lower case | $199.95–$249.95 |
| | G4 Aluminum 15" LCD Only1280x854 LCD / 15.2" | $179.95 |
| | G4 Aluminum 15" 1.5/1.67 GHz 8x SuperDrive (UJ-835)DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 4x DVD-RW write, 24x CD-R write, 16x CD-RW write | $199.95 |
| | G4 Aluminum 15" 1.5/1.67 GHz 8x SuperDrive (Used)DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 4x DVD-RW write, 24x CD-R write, 16x CD-RW write | $199.95 |
| | G4 Aluminum 15" 1.5/1.67 GHz 8x SuperDrive (Used)DVD-RW/CD-RW internal drive / 12x DVD read, 24x CD read, 8x DVD-R write, 8x DVD+R write, 4x DVD-RW write, 24x CD-R write, 16x CD-RW write | $199.95 |
| | G4 Aluminum 15" 1.5/1.67 GHz Upper CaseUpper case includes palmrest area, trackpad, trackpad cable, and power button. | $179.95 |
