PowerBook G4 Aluminum 15" Parts
The Aluminum 15" PowerBook was Apple's offering to fill the void between the small 12" and huge 17" Aluminum Powerbooks.
Two RAM slots can be stuffed with PC2700 RAM in these machines (except for the 1.67 GHz High-Res) for a memory boost. If you need more headroom, any 9.5mm ATA hard drive will fit in 15" Aluminums.
Sadly, the most commonly-faulty part in these notebooks are the RAM slots. If one or more of your RAM slots does not work, the logic board must be replaced to expand RAM. We carry a full variety of logic boards, depending on your model. Check out our Aluminum 15" troubleshooting guide for further help. We carry parts to restore your machine to working order!
Results
320 GB 5400 RPM Western Digital ATA Hard Drive (New)
ATA interface for PowerPC Macs / Western Digital / 2.5" wide x 9.5mm tall / 320 GB Unformatted / 5400 RPM
See full description
$169.95
160 GB 5400 RPM Western Digital ATA Hard Drive (New)
Easy storage upgrade / Western Digital / 2.5" wide x 9.5mm tall / 160 GB Unformatted / 5400 RPM
$149.95
250 GB 5400 RPM ATA Hard Drive
ATA interface for PowerPC Macs / 2.5" wide x 9.5mm tall / 250 GB Unformatted / 5400 RPM
$139.95
120 GB 5400 RPM Western Digital ATA Hard Drive (New)
Easy storage upgrade / Western Digital / 2.5" wide x 9.5mm tall / 120 GB Unformatted / 5400 RPM
$139.95
G4 Aluminum 15" Replacement Battery (New)
Upgrade your aging battery / 4400 mAh
$99.95
12.7 mm PATA 8x SuperDrive
Burn CDs and DVDs with your computer.
$89.95–$99.95
12.7 mm PATA 8x SuperDrive (UJ-846-C)
$89.95
G4 Aluminum 15" Rear Display Bezel
Replace a damaged bezel without the cost of a new LCD
$59.95–$69.95
G4 Aluminum 15" Display Inverter
A bad inverter board can cause a dead backlight
$69.95
G4 24x Combo Drive
G4 24x Combo Drive
Burn CDs and play DVDs with your laptop.
$59.95–$69.95
PowerBook
Main image
Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
My Cart
Your cart is empty.
