PowerBook G4 Aluminum 12" 1-1.5 GHz Parts
Apple's Aluminum 12" combines the form factor and internal layout of the iBook with the processing power of the PowerBook.
Upgrade to a 1 GB RAM chip and a 320 GB ATA hard drive to keep your laptop running like a champ. You can even upgrade the optical drive to a 8x SuperDrive to ensure fast CD and DVD burning. If your PowerBook has wireless trouble, throw in a replacement Airport Extreme card.
Not sure what's wrong with your broken machine? Check out our Aluminum 12" troubleshooting guide for help!
Select your machine above or browse all compatible parts to find what you need to fix your laptop!
Results
G4 Aluminum 12" 1/1.33/1.5 GHz Display Assembly
1024x768 LCD / 12.1"
See full description
$249.95–$349.95
G4 Aluminum 12" 8x SuperDrive (Used)
DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD+R write, 2x DVD-R, 2x DVD-RW write, 24x CD-R write, 24x CD-RW write
$199.95
G4 Aluminum 12" LCD Panel
LCD without the display bezels, hinges, or cables / 1024x768 / 12.1"
$149.95–$199.95
G4 Aluminum 12" 1/1.33/1.5 GHz Lower Case
Replace a scratched-up lower case
$149.95–$199.95
320 GB 5400 RPM Western Digital ATA Hard Drive (New)
ATA interface for PowerPC Macs / Western Digital / 2.5" wide x 9.5mm tall / 320 GB Unformatted / 5400 RPM
$169.95
G4 Aluminum 12" 1x SuperDrive
DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 1x DVD-R write, 1x DVD-RW write, 16x CD-R write, 8x CD-RW write
$149.95
160 GB 5400 RPM Western Digital ATA Hard Drive (New)
Easy storage upgrade / Western Digital / 2.5" wide x 9.5mm tall / 160 GB Unformatted / 5400 RPM
$149.95
250 GB 5400 RPM ATA Hard Drive
ATA interface for PowerPC Macs / 2.5" wide x 9.5mm tall / 250 GB Unformatted / 5400 RPM
$139.95
120 GB 5400 RPM Western Digital ATA Hard Drive (New)
Easy storage upgrade / Western Digital / 2.5" wide x 9.5mm tall / 120 GB Unformatted / 5400 RPM
$139.95
G4 Aluminum 12" LCD Only
$79.95–$99.95
